Home > Technical (L322) > transmission transmission oil td6 complete
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
Premise, I took the photos, but I am not a precise one, the work was done without lifting the machine.
this is the material you need
Post #528677 21st Sep 2019 6:48am
madcima
tools, many homemade
Post #528678 21st Sep 2019 6:49am
madcima
other vision in detail
Post #528679 21st Sep 2019 6:50am
madcima
I did not take pictures of the oil cup, and of the filter because those have already been seen
Post #528680 21st Sep 2019 6:51am
madcima
The procedure is simple, the cup is disassembled, leaving the 4 rear screws screwed in, because it remains about a liter inside, and so you can empty it, without dropping it on the ground.
Once the whole has been cleaned and the filter and cup are fitted, proceed with filling (4 liters)
Post #528682 21st Sep 2019 6:58am
madcima
Filling phase
Post #528683 21st Sep 2019 6:59am
madcima
other view of the filler cap
Post #528684 21st Sep 2019 7:05am
madcima
Now we proceed with the emptying of the converter and the cooling radiator.
The two tubes must be disassembled and the two o-rings changed and the radiator fluid drained
Post #528685 21st Sep 2019 7:11am
madcima
Once the liquid has been drained, refit the upper tube as shown in the photo (with the new o-ring)
Post #528686 21st Sep 2019 7:14am
madcima
tighten the collar, with the lower tube disconnected, and insert a drain extension in it (white tube)
Post #528687 21st Sep 2019 7:15am
madcima
For this operation, you need to be in two, or put a longer drain pipe
Start up for about 30 seconds, while the color of the oil from black does not turn red, when it happens, turn it off immediately.
Reconnect the tube with the new gasket, and proceed with filling
Post #528689 21st Sep 2019 7:27am
madcima
leave the hose connected
Post #528690 21st Sep 2019 7:27am
madcima
Top up with about 3 liters and start the engine.
remove the filling tube and put the cap on
pass all gear positions both normal and tiptronic up to 3
do 3 km
with the machine running unscrew the filling screw and add another liter
remove the filling tube and wait for the excess oil to stop flowing out
once you stop dripping, the level is correct
The game is done.
I recommend using a good quality original filter and dexron VI
and to change frequently (about 30000 km only oil) 90000 complete with filter
I hope I was helpful
Post #528691 21st Sep 2019 7:38am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Thanks for the write-up and pictures. I am sure this will be of help to anyone doing a fluid change who wants to get the old oil out of the torque converter via the cooler lines. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #528697 21st Sep 2019 8:41am
