![]() | Home > Technical (L322) > Splutter, jerk, judder restricted performance mystery SOLVED |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Just got this with Pat @Gap’s help
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Quick google and it mentions cracked inket manifold or dodgy actuator. Isn't there a regular issue with the inlet manifolds on a 4.4 tdv8? 2015 4.4 AB
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3819 ![]() ![]() ![]() |
https://www.google.com/url?sa=t&source...8308493845 2015 4.4 AB
Greg,
Thanks chaps. Out n about so grateful for all the info!
Illl make a separate post about this later, will be handy to many I’m sure. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 12th Sep 2019 7:40pm. Edited 1 time in total |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Greg
Greg
Ah yes now I remember Richard, thanks for the reminder.
Sent by email Greg, thought it would be easier for you to read.
Thanks Mike!
Also John, I checked the small loom and the L322 4.4TDV8 does indeed have the exact same connectors, loom and set up as your L405 SDV8.
Welcome, no problem.
I believe the issue with the wiring is a part problem Greg , when mine was replaced , the old ( original ) part look fine with no obvious issues. Hopefully yours is an easy fix and inexpensive |
