Home > Technical (L405) > [Solution] Keyless entry relay theft
Ukandrewf
Key less entry relay theft has been really worrying me since i bought my 2017 RR AU (6th most stolen car in the UK https://www.confused.com/on-the-road/safet...-revealed) so i did some research and found this page on JLR website....
https://www.landrover.co.uk/keylessentry/index.html
which says...
Quote:
Land Rover has implemented a new security feature to new vehicles in order to stay one step ahead of the criminals. This new feature is also available to existing customers through our retailers and resolves the current threat.
after much research and calling around, head office and the dealers i finally found what this security feature is... (and it's free if you're in warranty)
I don't think I'm revealing anything which will help thieves here (if you think i am delete the post admin) in fact it might reduce attempted thefts.
There is a way of locking the ignition module? to the two keys registered to the car - and no others. The dealer has to get a spare module in incase the existing module is corrupted during process in which case it would become undrivable. If you loose a key you will need a whole new module installed costing £130 plus the cost of the new key. But that might be a small price to pay for peace of mind.
Existing relay theft...
Works by amplifying the key signal from inside the house, next to bed etc with devices within 5m of key (if that's physically possible) and beams it to another unit next to the car and keyless entry is then fooled into thinking the key is close to the car and the thieves can just open the door as easily as you do.
(n.b. putting your key in a faraday pouch stops the signal (https://www.amazon.co.uk/gp/product/B07MW44691/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1) = if outside the pouch keyless entry works stood next to car but inside the pouch and next to car it doesn't - ie not signal emitted to be relayed.)
at this point the doors are open but the engine is not started.
Apparently the next step is to fool the car to thinking there is a third key in the car (a key has to be in the car for car to start) which then allows push button start and the thieves can drive off. 9 seconds start to finish apparently.
The solution above stops this because the system cannot accept a third key.
So while thieves might, at worst, be in the car they can't drive it off.
Hope this helps. --
On my third Full Fat RR
Post #527540 10th Sep 2019 11:24am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Interesting, but...............
Isn't the car started by using the relay also ? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #527542 10th Sep 2019 11:33am
Ukandrewf
i don't think they use the relay because that just beams the signal from the smart key - ignition requires a key to be present in the car to start but if once inside the car with access to that technical diagnostic socket thingy they can use a computer to fake/program a third key. then a key is shown to be present and the car starts.
[is this too much info might it help the crims? - although i'm far from technical] --
Post #527544 10th Sep 2019 11:50am
Bushy30
That's actually a fair point -- though, interestingly LR have been locking down the immobiliser ECU for some time -- it's called 'one shot programming'
From the video evidence I've seen (unless folk have cut the time line down) there isn't time to programme a third key before they drive off Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #527553 10th Sep 2019 12:49pm
Ukandrewf
somehow they're fooling the car into thinking there is a key inside to start it. i'm not sure relay of signal alone will do this. but perhaps it does..
i don't think they have cut down the video times.. saldy. it really is that fast.
the guy from the dealership said that with LR, relay allows them to get in but not to drive away. so they have less of an issue than other companies (looking at the most stolen cars above i'm not sure that's true..)
Andrew --
Post #527559 10th Sep 2019 1:19pm
supershuttle
I just put my keys in an old tin with a lid overnight. I know I could disable keyless entry but I do use it and value it. Geoff
Post #527572 10th Sep 2019 3:26pm
Ukandrewf
when in the tin have you taken next to the car to see if you can open it? --
Post #527573 10th Sep 2019 3:50pm
Chalky
I've got these from Amazon..
2x Sentry RFID Signal Blocking Keyless Entry Car Key Fob Pouches | Anti Theft Guaranteed | Black | 100% Artificial PU Leather | Maximum Protection All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #527574 10th Sep 2019 4:05pm
Phil.
I had the Meta Track VTS/S5 fitted to mine. It’s CAT 5 plus Thatcham approved. It includes a key fob and app that prevents the RR from starting even if the key is simulated to be in the vehicle. Without the fob it just won’t start. This prevents the signal from the key in the house being used to open/start the RR (key cloning). It’s been fitted for a while now and I’ve had no problems.
I used these guys who came highly recommended, have been very responsive and knowledgeable, and specialise in high value vehicles:
https://www.selectautosystems.co.uk/meta-trak/ MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #527587 10th Sep 2019 5:06pm
andygts
I've just put a deposit down on an L405, one of these www.keylessprotector.com will be my first purchase and the battery removed from the spare fob.
The relay device makes the car think that one of the assigned keys is present so will start and away your car goes. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #527595 10th Sep 2019 5:45pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I usually put my key in a double skinned metal wine cooler.......but there's been times I'd place it as close to the front door as possible Whistle
Post #527598 10th Sep 2019 6:45pm
CS
Wrapping the keys in kitchen aluminium foil works fine, when I tried a metal tin the car still opened. Only Range Rovers since 1988
Post #527599 10th Sep 2019 6:49pm
roberlar
That surprises me. Beyond 6ft. or less without any shielding mine won't respond at all.
Post #527600 10th Sep 2019 6:55pm
Ukandrewf
they boost signal to make it look like key is right outside the door? is that what you mean? bridge it with one device at the house nearest the key and another next to car. --
Post #527602 10th Sep 2019 6:58pm
roberlar
That's pretty much how it seems to work, although my comment was somewhat facetious !
Post #527603 10th Sep 2019 7:11pm
