![]() | Home > Technical (L405) > [Solution] Keyless entry relay theft |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 360 ![]() ![]() |
Current
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 246 ![]() ![]() ![]() |
i think all new models have issues. the best advice is not to buy the first of a new model. let them find and fix the problems for you first...
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
I bought an L322 brand new in 2004. Unbelievably it had no problems at all in the fourteen years I owned it. Yes, it had a couple of years grace following introduction, however this isn't a valid excuse for the model to exhibit certain issues, and quite clearly this forum shows problems do exist way beyond the introduction post 2013. That said, we all have the choice,. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3869 ![]() ![]() ![]() |
My tin isn’t perfect but it does reduce the range of the signal Geoff |
for £7 for two pouches which are 100% effective why not get the real thing to protect such a high value asset? just saying...
Actually I disabled keyless - much better - it was a solution looking for a problem. It looked so hard it created one, L405s with keyless are too easy for thieves to get inside. Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
its kinda satisfying that when you press the keyfob and the mirrors go in that its positively locked... ... - .- -.
This is probably the most sensible solution. Andrew -- On my third Full Fat RR |
