Home > In Car Electronics (L322) > Upgraded to discovery 4 BT but still pin request
elblanco
Ireland 2007 Range Rover Vogue SE TDV8 Santorini Black
Hi All
I upgraded to discovery 4 Bluetooth module using the guide on wiki for wiring instructions. All worked fine and can now see address book on the l322 screen and caller ID works as expected.
However each time I start up car it asks me for pin number on phone and doesn't connect unless I input 2121 which is pretty annoying each time, what have I done wrong? Any ideas? Thanks!
Post #527453 9th Sep 2019 12:29pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
What phone are you using?
Post #527476 9th Sep 2019 5:39pm
elblanco
Using a Samsung galaxy s8 android phone, hope that helps?
Post #527477 9th Sep 2019 5:41pm
elblanco
Just an update here, i now have this working. Problem was...
Phone was paired to original Nokia system, I didn't unpair and wired up BT box from LR4, phone asked for pin every time which is annoying.
I unpaired phone and disconnected new BT box for 30 mins, then reconnected and repaired and all works perfectly!
Post #527836 12th Sep 2019 6:10pm
