Home > In Car Electronics (L322) > L322 touchscreen sat nav error |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Have you got a photo of the disc? Current: 2011 FFRR Vogue SE 4.4 TDV8
4th Sep 2019 11:16am |
JonnyO Member Since: 01 Sep 2019 Location: Loughborough Posts: 28 |
Should be able to get one in a few days |
4th Sep 2019 11:51am |
I suspect exactly as it says -- wrong disc, or corrupted disc, dare I suggest non original? Current: 2011 FFRR Vogue SE 4.4 TDV8
4th Sep 2019 12:06pm |
Well, it’s an original disc. I got it out once. Put it back in again. Now it won’t eject. Should I suspect the drive do you think? |
7th Sep 2019 5:17pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3240 |
I had similar, the disc not ejecting. The GPS was throwing up errors too. It was down to a problem with the pins on the plug to the drive. As a first step take it out and check the pins for integrity and also for verdigris. Mine were quite heavily corroded.
7th Sep 2019 5:35pm |
Pulled the unit out and no pin damage or corrosion. Also got the disk to eject. May try replacing the disk first and crossing my fingers. Where can I obtain a new disk? |
8th Sep 2019 6:52pm |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
IMHO.. Not worth spending considerable money on fixing an outdated poor LR satnav system, unless your a stickler for originality and needing everything having to work.
9th Sep 2019 11:49am |
Thats probably what I'll end up doing. Might try a few quid on a new disk in case its that simple and cheap but no more than that. |
9th Sep 2019 1:10pm |
Just to close this up. After plugging and unplugging the computer module it sprung into life. |
17th Aug 2020 8:41pm |
Billie Member Since: 12 Oct 2020 Location: south-west Posts: 49 |
I know this is a couple of months old but can I ask what disc you are using. I have the DVD-ROM from Japan, for Land Rover dated 2005 but underneath it states : 1993-2004 NAVTEK. When I insert the disc the screen states "wrong disc"
28th Oct 2020 12:06pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 589 |
You have the same car as mine so this is what I purchased
28th Oct 2020 1:00pm |
Ooops, sorry didn't mean to cause any hassel |
30th Oct 2020 6:42am |
