![]() | Home > Technical (L322) > AGM battery and the lack of one |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Sorry to start a new thread on an existing problem but will the lack of an AGM battery cause a restricted performance fault? My 2010 3.6 has a standard battery on it and I don’t think it’s performing at its best. If I leave a door open the voltage will drop on IID tool to 11.7
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
I don’t know how the iid actually measures the battery voltage but it is not necessarily a true and accurate reading.
pawsinmud Member Since: 26 Mar 2019 Location: Hampshire Posts: 34 ![]() ![]() ![]() |
I posted on another thread about AGM as my 2011 TDV8 has an 017 flooded battery and I keep getting a 'Low Battery please start engine' warning on the instrument display then everything shuts down.
All. 2011 4.4 tdv8’s should have an AGM battery because they did a recall to change out the battery to upgrade to AGM.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
On my 2011 4.4 VSE ,even with a new AGM , the low battery warning came up quite often . Even if i open or shut the doors alot during cleaning etc. Never had any trouble with it starting so always thought it was just very sensitive to voltage. On my 2015 4.4 AB you can open and shut the doors seemingly all day and have never had the warning. Both cars have / had deployable side steps. Just my experience sir |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4328 ![]() ![]() ![]() |
I plug in my ctek on 12V feed into the towing electrics via the adaptor sold on forum shop when I’m cleaning etc.
When mine is plugged in I am in holiday mode |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
like the box |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
My 2010 4.4 TDV8 has an AGM battery. I've never seen the low battery warning even when the previous battery was on its way out. The only symptom I had was that the Webasto wouldn't fire up. 2010 4.4 TDV8 Vogue SE |
I have something attached to the positive lead that sits down the side of the battery. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
