Home > Technical (L322) > AGM battery and the lack of one
Andy
Sorry to start a new thread on an existing problem but will the lack of an AGM battery cause a restricted performance fault? My 2010 3.6 has a standard battery on it and I don’t think it’s performing at its best. If I leave a door open the voltage will drop on IID tool to 11.7
If I fit a new AGM will I finally cure the fault? Others say I will on the facebooks.
Thanks 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #527126 5th Sep 2019 9:02am
Baltic Blue
I don’t know how the iid actually measures the battery voltage but it is not necessarily a true and accurate reading.
I have proved this 100% by measuring the battery voltage directly across the terminals on my trusty old AVO and comparing it to the iid reading.
My suspicion was raised when I tried using the iid without the engine running, then connecting a CTEK across the battery in order to be able to use the iid without flattening the battery.
Post #527134 5th Sep 2019 9:56am
Andy 11.7 is about right for reading with an IID sir... Thumbs Up
That said, it should only have an AGM battery if the battery charging system updates were done and yours didn't slip through the net! Whistle Does it have some electrical gibing sat onto of the battery?
Post #527193 5th Sep 2019 10:40pm
pawsinmud
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I posted on another thread about AGM as my 2011 TDV8 has an 017 flooded battery and I keep getting a 'Low Battery please start engine' warning on the instrument display then everything shuts down.
My battery has a load of stuff partially hiding it - is that how I know whether I should have an AGM or not? 2011 TDV8 Vogue SE
Post #527306 7th Sep 2019 10:15am
Baltic Blue
All. 2011 4.4 tdv8’s should have an AGM battery because they did a recall to change out the battery to upgrade to AGM.
The battery control unit is fitted in front of the battery, but it is worth noting some have a fan fitted but some don’t.
Sorry I have no idea why ( Rolling with laughter maybe the fan fitter had a few days off )
Post #527310 7th Sep 2019 11:30am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
On my 2011 4.4 VSE ,even with a new AGM , the low battery warning came up quite often . Even if i open or shut the doors alot during cleaning etc. Never had any trouble with it starting so always thought it was just very sensitive to voltage. On my 2015 4.4 AB you can open and shut the doors seemingly all day and have never had the warning. Both cars have / had deployable side steps. Just my experience sir Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #527313 7th Sep 2019 12:31pm
DrRob
I plug in my ctek on 12V feed into the towing electrics via the adaptor sold on forum shop when I’m cleaning etc.
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #527318 7th Sep 2019 2:04pm
Baltic Blue
When mine is plugged in I am in holiday mode Very Happy
Post #527322 7th Sep 2019 2:52pm
nino_nino
like the box Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #527357 8th Sep 2019 8:20am
kooky_guy
My 2010 4.4 TDV8 has an AGM battery. I've never seen the low battery warning even when the previous battery was on its way out. The only symptom I had was that the Webasto wouldn't fire up. 2010 4.4 TDV8 Vogue SE
Post #527423 9th Sep 2019 6:42am
Andy
I have something attached to the positive lead that sits down the side of the battery. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #527819 12th Sep 2019 4:21pm
