Home > Technical (L322) > Electronic oil level readings change
dazza1983
So I know how to check the engine oil level ... the issue is which reading do I believe lol.
So get in my car after work cars been sat for hours. Check the level and it’s one bar above half way mark.
Go completely out of the menu and go back into it and check again same level go back out again and go for one more check and the level is now one mark down from full up. Now the level seems to stay at this reading if I go out and do numerous re checks. This has happened a few times. What reading do you believe lol? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #527106 4th Sep 2019 8:36pm
DrRob
Check it cold in the morning before start up. Should be just above mid line. Check it over a few mornings readings. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #527128 5th Sep 2019 9:27am
nino_nino
It can take up to 20 sec. for reading to stabilize, so wait for the final reading.
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #527137 5th Sep 2019 10:16am
dazza1983
Just wanted to add to this as I completely overlooked it.
And it may help someone else lol.
Manual does state for petrol and 4.4D models engine oil must be checked at working temperature so hot. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #528386 17th Sep 2019 8:40pm
