![]() | Home > Technical (L405) > Restricted Performance SDV8 4.4 |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Good to know |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Before cleaning
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I clean mine at every oil change (5K km). |
+1 every 6 months, which with my low mileage works fine.
carrint71 Member Since: 13 Sep 2019 Location: East Anglia Posts: 4 ![]() ![]() |
Where do I find the MAP sensor please? |
Just pull the engine cover off and...
Thank you!! |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
on this, I'm a little confused, I thought a MAP (some cars used a MAF) sensor was the thing that sits usually just after the air filter on the intake to measure air pressure / flow ??
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
I Got the restricted performance again so called Land Rover assist who said that it may be a turbo actuator issue.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Probably not a turbo actuator Terry, could be a loose or split hose.
It's in the dealers at the moment so will see what they come up with. Said they would get back to me in 48 hours which was up today so I will call tomorrow.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
^^ Standard! ^^
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1391 ![]() ![]() ![]() |
To be fair LR recommend not going below 3mm. Only Range Rovers since 1988 |
Finally got the car back. They replaced the compressor shut off valve and turbo. Glad that was under warranty 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9 2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy. |
