Home > Technical (L405) > Disable all interior lights? |
pawsinmud Member Since: 26 Mar 2019 Location: Hampshire Posts: 34 |
On most Land Rovers if you press and hold the interior light switch for about 3 seconds, the lights will flash and then they are switched off, You can turn them back on the same way. 2011 TDV8 Vogue SE |
2nd Sep 2019 9:01pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4301 |
Wot he said ^^^ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd Sep 2019 9:26pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
yours will be touch sensitive but the disable works the same way as described above.... ... - .- -.
3rd Sep 2019 5:57am |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1230 |
Good to know , as on occasions non fare paying freeloaders in the back adjust the airflow and inadvertently touching the lights, which then remain on.... Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
3rd Sep 2019 8:17am |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1016 |
I think its called stealth mode. My car had been set that way so had to consult the oracles on here to find out how tonswitch back to normal |
4th Sep 2019 10:45am |
