Home > Technical (L405) > Disable all interior lights?
mikemike39
We are by the French coast for a couple of weeks and the RR houses a lot of our stuff - we will be endlessly opening and closing doors etc. I'd like a button or menu setting that kills all the interior lights for the duration so the battery doesn't become drained. I can't see anything which does this, although maybe I'm being thick? I did also wonder whether the lights were LED so the power drain is minimal - it's a 2016 66 plate
Can anyone help?
Mike
Post #526896 2nd Sep 2019 9:51pm
pawsinmud
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
On most Land Rovers if you press and hold the interior light switch for about 3 seconds, the lights will flash and then they are switched off, You can turn them back on the same way. 2011 TDV8 Vogue SE
Post #526898 2nd Sep 2019 10:01pm
DrRob
Wot he said ^^^ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526900 2nd Sep 2019 10:26pm
yours will be touch sensitive but the disable works the same way as described above.... ... - .- -.
Post #526914 3rd Sep 2019 6:57am
Bill
Good to know , as on occasions non fare paying freeloaders in the back adjust the airflow and inadvertently touching the lights, which then remain on.... Thumbs Up Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #526928 3rd Sep 2019 9:17am
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I think its called stealth mode. My car had been set that way so had to consult the oracles on here to find out how tonswitch back to normal
Post #527024 4th Sep 2019 11:45am
