Home > Technical (L322) > Cam cover gasket replacement cost? 4.4 V8 |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
i changed mine
1st Sep 2019 5:36am |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 |
Did you change them yourself? |
1st Sep 2019 7:33am |
yes RR 2005 4.4 petrol
1st Sep 2019 7:39am |
This is why I think I might be better paying an expert! |
1st Sep 2019 7:41am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
You’ll be lucky to find a garage to just change the gaskets... They are a rubbish design! Most garages want to replace the rocker covers too as they warp with age! Then leak immediately again! This then leads to complaints, hence most wanting to change the lot!!! |
1st Sep 2019 7:54am |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 |
I did mine and found it a bit fiddly when I tried not to remove the injectors and associated bits. On the other side I did remove them and it made it a lot easier.
1st Sep 2019 4:39pm |
