Home > Technical (L322) > Cam cover gasket replacement cost? 4.4 V8
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I know it can be done DIY, but with my never ending propensity to mke a mess, I am considering getting an indy to a job.
Does anyone know how much you would expect to pay for the cam cover gaskets to be changed an the 4.4 V8 BMW engine?
Thanks
Post #526690 31st Aug 2019 8:08pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
i changed mine
they are leaking more now than before i started RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #526705 1st Sep 2019 5:36am
philip1972
Did you change them yourself?
Post #526716 1st Sep 2019 7:33am
knares
yes RR 2005 4.4 petrol
Post #526717 1st Sep 2019 7:39am
philip1972
This is why I think I might be better paying an expert!
Post #526718 1st Sep 2019 7:41am
You’ll be lucky to find a garage to just change the gaskets... They are a rubbish design! Most garages want to replace the rocker covers too as they warp with age! Then leak immediately again! This then leads to complaints, hence most wanting to change the lot!!!
Post #526719 1st Sep 2019 7:54am
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
I did mine and found it a bit fiddly when I tried not to remove the injectors and associated bits. On the other side I did remove them and it made it a lot easier.
With some decent sealant for the joins on the timing cover case and the half-moons on the rear, it should be an OK DIY job.
Replace all the rubber bushings on the cam cover bolts too as they hard likely to be hardened.
I'd advise having an inspection mirror tool on an extending stick too, makes checking gasket seal on the half-moons easier.
Oh, don't do as I did and let the earth strap curl over and sit between gasket and cover on fitting.
Plenty of YT vids on BMW M60 replacement to follow.
Post #526758 1st Sep 2019 4:39pm
