Home > Maintenance & Mods (L322) > 4.4 eats its timing chain tensioners \ guides what to do?
Cryptic
2002 Range Rover Vogue 4.4 V8 Java Black
Anyone else had their engine eat the plastic timing chain tensioner \ guides? Mine has - the evidence being plastic bits that blocked the strainer causing all hell to break loose in low oil pressure \ stop engine warnings on the dash.
If so, what did you do to fix?
I guess those bits of plastic are throughout all the oilways - and cleaning out not just an expensive job, but might not be really possible.
Replace engine?
Post #526450 29th Aug 2019 1:31pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
How many miles on this set?
Post #526451 29th Aug 2019 1:37pm
Cryptic
Just over 100k
Post #526452 29th Aug 2019 1:44pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
The guides become brittle due to high running temps of the engine. NO choice but to take the front off and replace the guides. Mine cost £3000.
https://www.fullfatrr.com/forum/topic41142.html?highlight=guides
Post #526457 29th Aug 2019 2:27pm
Cryptic
Thanks for that and the link.
Thoughts on the plastic bits - is there a risk of them still being round the engine and causing same strainer blocking in future?
Post #526458 29th Aug 2019 2:42pm
Brian Considine
If you still have the bits then weight them and whats left, compare the weight to replacements & that should give you an idea of how much is actually unaccounted for.
May help you make a decision. 2003 Range Rover Vogue TD6
Post #526460 29th Aug 2019 3:07pm
Dolphinboy
Yep you will have to access the filter and flush out. Holidayhicken on this forum is my SME (subject matter Expert) on this engine as well as JohnBoyAirey.
Good luck. Hope you get it up and running cos they have a lot of life in them if you do. Thumbs Up
Post #526464 29th Aug 2019 3:53pm
Cryptic
Mech reckons that given the great condition underneath she's worth saving one way or another . Currently he's concerned about the remaining floating plastic bits and is thinking replacement engine - if a decent one at the right price can be had. But will discuss further.
Post #526485 29th Aug 2019 6:42pm
doclees
80 to 100k miles seems about average. It's just a maintenance item. Mine we done by PO at 110k miles. So at 190 to 200k I'll do them and the Besian Vanos fix.
Post #526508 30th Aug 2019 1:31am
p38arover
Australia
Just a maintenance item? At GBP3000 (nearly AU$5,500)? Crikey! That's nearly the price of a secondhand L322.
I've looked at the work required and it's not a maintenance item. It is a major job.
Cryptic: How many times have they been replaced? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #526509 30th Aug 2019 1:40am
Cryptic
Never, to my knowledge - not in the 40k I've had her anyway. Wasn't a potential problem I was aware of.
Post #526612 31st Aug 2019 6:50am
p38arover
Australia
I thought it must have been multiple times from the thread title.
I'd like to do mine but it looks like too big a job for me. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #526624 31st Aug 2019 8:08am
Cryptic
Been watching videos - it does look a lot of work but not necessarily that difficult (notwithstanding specific tools needed and encountering bolts that won't move)
Post #526692 31st Aug 2019 8:24pm
doclees
Maintenance. Do you wait until your oil stops lubricating before changing it? Of course not. Most don't have a sample sent for evaluation. We just change it at 5-10k miles. Here a timing chain kit goes for about $400 usd with a lifetime warranty. Yeah there is some wrench (spanner) time involved. Good time to do anything else on the way. Even an alternator or starter is a maintenance item if you want uninterrupted use. We usually just wait until they break because when they break they don't cause something else to break. I guess an alternator could take out a battery too. A sloppy timing chain could get ugly real fast. We now know "sealed for life" means change every 60k miles or it's life will be short.
Don't confuse routine maintenance with. Preventative or Predictive maintenance. In an ideal engine we could easily inspect those timing chain guides to check for cracks and wear. We can't . We can predict when these guides and chains need replacement from average miles at failure and turn it into preventative maintenance. Just another BMW idiosyncratic designs.
Post #526694 31st Aug 2019 8:45pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
I am going through this now and for the last couple of years and have not got it right yet.
Like p38arover said it’s a major job
Doing it again, I am a lot wiser
I went to BMW and asked them to do a diagnostic test; they did not want to do it.
I went to a land rover specialist to do a diagnostic test, when I mentioned BMW, they would not touch it
I went to another land rover specialist to do a diagnostic test, they did the test but said they did not touch BMW
They are a major RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #526703 1st Sep 2019 5:31am
