Home > Maintenance & Mods (L322) > Oil filter fitment |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
I have fitted 2 of these, and about to change again even though I have only done 3k miles since last change, but a lot of local short trips.
17th Apr 2019 10:04am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
I also use the Mahle filters on my 3.6 TDV8
17th Apr 2019 10:22am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
Weird that, just ordered a gen filter from Dan. Was a fomoco filter made by Mann. So it looks like Mann do 2 different filters for the car!! As it doesn’t look like the Mann Nino_nino has, Wells amen save for the cord round the outside. There is nothing that can't be fixed with a hammer😜😜
17th Apr 2019 9:11pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
nmj can you put picture up, pls.
18th Apr 2019 9:55am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
What I don't understand is this: -
18th Apr 2019 10:41am |
dpm Member Since: 14 May 2018 Location: grimsby Posts: 36 |
I got the MANN filter yesterday came with a bag of 'O' rings but can't see where they all go, on the old filter which is same as new one even the filter casing hasen't got one on, are they not used ? |
25th Apr 2019 9:29am |
You. need to fit the sealing ring as shown in green on the following...
25th Apr 2019 9:38am |
OK thanks, I guess the other 'O' rings not used. |
25th Apr 2019 9:49am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I assume the filter pulled out and left the cage inside the casing ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
28th Aug 2019 8:41pm |
That Mahle one has a raised area on the end compared to the Genuine one...?? For reference, scroll right down too see 3 different ones: Hengst, Genuine and Mahle https://www.advancedfactors.co.uk/service-...-168-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
28th Aug 2019 8:43pm |
Rob,
29th Aug 2019 6:47am |
That would assist in either of them fitting perfectly then Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Aug 2019 7:56am |
DrRob,
29th Aug 2019 7:58am |
Nino
29th Aug 2019 9:21am |
