Home > Maintenance & Mods (L322) > Oil filter fitment
Page 2 of 3 <123>
Baltic Blue
I have fitted 2 of these, and about to change again even though I have only done 3k miles since last change, but a lot of local short trips.
Post #512359 17th Apr 2019 10:04am
I also use the Mahle filters on my 3.6 TDV8
No problems, as clean and tidy as Nino's image Thumbs Up .
Post #512361 17th Apr 2019 10:22am
cass
As someone who wrecked a Kawasaki bike engine in the 1980's as the result of a failed cheap oil filter, I struggle to see why anyone would contemplate fitting anything other than a Land Rover oil filter?
My experience may have made me paranoid but it also taught me the importance of the lubrication system, the cost of the "proper" oils and filters is a drop in the ocean of total ownership costs.
Post #512389 17th Apr 2019 4:21pm
Weird that, just ordered a gen filter from Dan. Was a fomoco filter made by Mann. So it looks like Mann do 2 different filters for the car!! As it doesn’t look like the Mann Nino_nino has, Wells amen save for the cord round the outside. There is nothing that can't be fixed with a hammer😜😜
Post #512439 17th Apr 2019 9:11pm
nino_nino
nmj can you put picture up, pls.
this is Amazon > https://www.amazon.co.uk/OEM-Filter-Elemen...WYQA7SFVCR
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #512498 18th Apr 2019 9:55am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
What I don't understand is this: -
Why, if these fit, would MANN not claim that on their own website? surely they're missing a trick? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #512500 18th Apr 2019 10:41am
dpm
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I got the MANN filter yesterday came with a bag of 'O' rings but can't see where they all go, on the old filter which is same as new one even the filter casing hasen't got one on, are they not used ?
Post #513126 25th Apr 2019 9:29am
Baltic Blue
You. need to fit the sealing ring as shown in green on the following...
Ike. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #513128 25th Apr 2019 9:38am
dpm
OK thanks, I guess the other 'O' rings not used.
Post #513129 25th Apr 2019 9:49am
DrRob
Tinman wrote:
I did mine yesterday and the cage stayed in the filter case? so should pull out easily look at your new filter you will see that there is nothing to hold it. just `O` ring
I assume the filter pulled out and left the cage inside the casing ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526395 28th Aug 2019 8:41pm
DrRob
Mike.
That Mahle one has a raised area on the end compared to the Genuine one...??
For reference, scroll right down too see 3 different ones: Hengst, Genuine and Mahle
https://www.advancedfactors.co.uk/service-...-168-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526396 28th Aug 2019 8:43pm
Baltic Blue
Rob,
The inside of the filter housing has a spring tensioner that pushes against the filter, and the Mahle fits perfectly .
Post #526409 29th Aug 2019 6:47am
DrRob
That would assist in either of them fitting perfectly then Thumbs Up Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526415 29th Aug 2019 7:56am
nino_nino
DrRob,
if you enlarge picture of the genuine land rover filter from advance factors site, you can see it is MANN filter 718/4x which is supersideed with 718/5x like mine in my post. check Amazon site
https://www.amazon.com/Mann-Filter-HU718-4X-Element/dp/B000CB94TU
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #526416 29th Aug 2019 7:58am
DrRob
Nino
Yes, I noticed it said Mann on the Genuine one I have bought Thumbs Up
What's this "cage thing" I read about in earlier in this thread?
Rob Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526425 29th Aug 2019 9:21am
Page 2 of 3 <123>
