![]() | Home > Technical (L322) > Not starting |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
So a few weeks ago had a problem with the car not starting after about 4 hours towing the tin tent stopped for a break, Foot on brake press button no turn over just click? When it did start after a number of times pushing button started every time?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
IID show any other fault codes?
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Fuel pump? Should be a 2 minute job to rule out |
Hi, mpirie, That sounds more like what I am looking for as I have no problem when cold or short runs, I agree pump would only be if it would not fire but turn over all I get is a click? after it cools down it starts. |
When my fuel pump went it didn't try to turn over, as I say, a 2 minute job to check |
How did you check the pump? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I remember reading someone had a problem with the cable from the battery to the starter. It is several sections and had a bad connection from the starter relay from memory?
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I replaced mine on my 2007 last year bought the whole harness as had a similar issue with my p38 and it was corrosion inside the cable and when hot just not delivering enough - on the p38 bought a premed from auto factors and just put it in as well as original |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 903 ![]() ![]() ![]() |
Tinman, have a search for "4.4 tdv8 starter".
Cheers Mike on my way to investigate Thanks for the tip |
Here you go: https://www.fullfatrr.com/forum/topic31909...rter+cable
