Home > Technical (L322) > She died......4.4 BMW petrol
Wafoo81
United Kingdom 2005 Range Rover Vogue 4.4 V8 Barolo Black
Coming back from a lovely jaunt round Holland Belgium and France, on the M4 stuttered EML came on and pulled onto hard shoulder, was ticking over but wouldn't rev, got my reader on it and it said Bank 1 & 2 lean, started again, cleared the codes got 50 yards same again, so spent the rest of the journey on a low loader, started this morning and running fine, Since I cleared the codes and lost the bit of paper I wrote them down on anyone any ideas where to start, Fuel pump, filter?? Current:
2005 4.4 V8 FF
Chrysler Crossfire
Previous:
BMW X3
BMW Z4
Saab Aero
Saab Convertiible (lots)
Mazda Rx8 (lots)
BMW 320 msport
Mini Cooper JCW
MG ZT (loved these cars)
and numerous nails from 1985
And bikes, lots and lots of bikes ๐Ÿ˜Š
Post #526205 27th Aug 2019 7:07am
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Can't be much help I'm afraid, but all I can say is that when my fuel pump went, I didn't get anything like those messages. Hopefully someone with a bit more specific knowledge will be along shortly
Post #526221 27th Aug 2019 9:52am
Gsxr1250dave
Swop out the fuel pump there known to fail easy enuff job
Post #526269 27th Aug 2019 6:07pm
Wafoo81
Well, stumped took her for a drive last night, faultless for an hours driving around up hill down dale, only fault it picks up is the one attached
Strange readings on the icarsoft reader
O2 sensor voltage B1-S2 doesn't appear to vary much stays at approx. 33v whereas B2-S1 varies depending on throttle position
Fuel trim B1-S2 stuck at 99%
B2-S1 short term fuel trim 3%
B2-S2 short term fuel trim 99%
B1-S1 short term fuel trim 0%
O2 sensor output B1-S2. 33v little variation
Short term fuel trim B1-S2 99%
Anyone any ideas, I would have thought all the voltages would vary depending on load and same for the 99% fuel trims??
No panic, found it with a bit of hunting, the 99% is normal as it's downstream of the cat and should read high as its showing no unburnt fuel and the O2 sensor is the same as it's the downstream one and shouldn't be adjusting for anything, so I might give the MAF a clean Current:
2005 4.4 V8 FF
Chrysler Crossfire
Previous:
BMW X3
BMW Z4
Saab Aero
Mazda Rx8 (lots)
BMW 320 msport
Mini Cooper JCW
Post #526312 28th Aug 2019 6:57am
Danwilderspin
That fault I believe is to stop fuel tank pressure building up I had that go and replaced from bmw about 50 made it run better for sure.
When did you last have your pcv changed? The reason I ask mine was changed last year but they forgot to swap the bing over (casing a vac leak) and it drove exactly like yours. Swapped it over and hey presto - or it mayb he pcv itself?
If thatโ€™s been done fairly recently get yourself booked in for a smoke test! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526401 28th Aug 2019 10:35pm
Wafoo81
Thanks for the info, the valve has not been changed to my knowledge so I'll get that changed this weekend, I'll do the MAF at the same time Smile Current:
2005 4.4 V8 FF
Chrysler Crossfire
Previous:
BMW X3
BMW Z4
Saab Aero
Mazda Rx8 (lots)
BMW 320 msport
Mini Cooper JCW
Post #526431 29th Aug 2019 10:17am
Danwilderspin
Sorry just saw this - did you get the part yet!? Itโ€™s a bmw part used on the 540i e39 too and itโ€™s less than half the price from Bmw than lr! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #527413 8th Sep 2019 9:21pm
Wafoo81
Yeah, all changed, changed purge Valve which cleared one fault and changed the thermostat which has fixed the other, not done any big miles yet but in two weeks of driving around no issues yet....Smile Current:
2005 4.4 V8 FF
Chrysler Crossfire
Previous:
BMW X3
BMW Z4
Saab Aero
Mazda Rx8 (lots)
BMW 320 msport
Mini Cooper JCW
Post #527528 10th Sep 2019 10:15am
