Home > Technical (L322) > Help what is this |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Wow !
22nd Aug 2019 6:23pm |
Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87 |
Seriously is it ok to drive have to drive tomorrow it was quick fit replaced discs and pads twice now if it’s of to drive I will go Saturday
22nd Aug 2019 6:27pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 |
If you decide to go back, insist on watching when they work on it. If it is missing, take a pic and threaten Trading Standards. Might get you a partial refund.
22nd Aug 2019 6:48pm |
Thanks guys should they not have noticed this when replacing discs and pads
22nd Aug 2019 7:30pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Given the age of your RR you may find that the reason the shoe retaining spring has come out is due to corrosion on the back plate. If that is the case then the back plate will need to be replaced or the retaining spring will keep falling out, however the back plate is not easy to replace. 56 TDV8 Vogue SE
22nd Aug 2019 8:07pm |
Andy J - although I understand your comment based on the state of many RR front brake dirt shields, the backplates should be nowhere near that badly corroded that the spring retaining pins pull out on a 2007 car - unless it's been in incredibly harsh environment.
22nd Aug 2019 8:16pm |
In the unlikely event that the registration hole for the spring assembly has corroded how about using one of these against the back plate :-
22nd Aug 2019 9:46pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
He is from Scotland and they suffer far worse corrosion, the further north you go sir... |
22nd Aug 2019 11:01pm |
