Home > Off Roading & Green Laning > Ullswater trip coming up wanted to go play off road.
dean-278
England 2009 Range Rover Vogue SE TDV8 Santorini Black
hi all
newbie here is there any places near Ullswater I could go for a play in my ffrr Very Happy
thanks
dean
Post #525638 21st Aug 2019 7:36am
Baltic Blue
The road round the back of Ulswater is interesting. If you go up to Pooley Bridge then follow the narrow road to Howtown, keep going up the very steep hill section past St Peters Church you can get access on to the fells of Martindale.
I have walked round the southern tip of the lake back into Patterdale, but I am not sure if the gates are locked during summer months, in which case you would have to return back via Pooley Bridge.
If you have any interest in history, check out the wartime story associated to St Peters church , and the stained glass window dedicated to the Merchant Navy.
The views from the top of Martindale looking across the lake are among the best in the area, ...stunning.
Mike.
PS.
Last time I went I actually parked up at Howtown and got the ferry to Glenridding, then walked back around the southern tip of the lake, which is moderately easy, but on a clear day, breathtaking. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #525648 21st Aug 2019 8:53am
dean-278
thanks will definitely take a look
dean
Post #525656 21st Aug 2019 9:45am
Baltic Blue
I would recommend buying the local OS map and you will see all the tracks marked.
Post #525658 21st Aug 2019 9:51am
