Home > Maintenance & Mods (L322) > DIY aircon top up |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 |
Can you put a link to wear you ordered from please?
7th Aug 2019 12:37pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Got the gas from these guys https://www.thompsonsltd.co.uk/motoring-aircon/ I got the 3 can pack its about £40 delivered there on eBay maybe free postage or what ever on that site .Pipe and gauge off fleabay ( cheaper ) don't get the Chinese gas as it's a different fitting
7th Aug 2019 1:10pm |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 |
I re-gassed my Td6 in May myself after I changed the air condenser out. Really easy job just keep an eye on the psi. Gas was about £50 from Halfords (was looking for a groupon but none about at the time). If just doing a top up the can should be good for 2 or 3 cars.
7th Aug 2019 6:39pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 370 |
ATS are only charging £59 for air con recharge around here, don't know about other areas, and if it has a leak and won't take the charge then you don't pay. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
7th Aug 2019 6:44pm |
When I had the disco I used ats, sat for an hour then guy says cant do theres a vacuum problem leak I says don't know says guy sorry, waste of an hour
7th Aug 2019 6:56pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
£37.99 at ATS at the moment if you use a Groupon Coupon. |
7th Aug 2019 6:57pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
How did you vacuum out all of the air & moisture? did you change the drier too? BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
7th Aug 2019 7:22pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
I found a specialist air con guy to do mine as a preventative maintenance...gas has gone up in price
7th Aug 2019 8:03pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
I'll second the route that Dr Rob took.
8th Aug 2019 10:18am |
Wafoo81 Member Since: 05 Jul 2019 Location: Pontypridd Posts: 18 |
Groupon were doing a deal at £39 with ATS, if it's finished Kwik-fit do it all for £59, same thing pressure test, leak check and refill, saves the guesswork |
8th Aug 2019 10:33am |
It's been about 11days since I diy fixed my aircon and so far it is performing great , only needing to go on a low fan setting to keep the car super cool , wife says it's too cold
18th Aug 2019 5:36pm |
About the same as a trained air-conditioning engineer charges (one who does not fit tyres). Good luck with any Quickfords type outfits - past experience means none of my vehicles ever go there - not even for tyres (as it happens one of them jacked a vehicle of mine up using the floor pan !) 2003 Range Rover Vogue TD6 |
18th Aug 2019 5:54pm |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 |
Local car aircon place charges £50 and have knowledge on just about every car. It's so cheap as to be not worth bothering with DIY or untrained Halfords type places with the only ability to top up.
18th Aug 2019 8:04pm |
Agricultural engineers (repairs to tractors and combines) do a great job and know their stuff at farmers prices! BMW i3 Electric Car
19th Aug 2019 3:32am |
