Home > Maintenance & Mods (L322) > DIY aircon top up
Cwmdu86
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Had mine done with ATS (Groupon) recently for £39. The guy who did it said it took about 3 times the amount they normally put in.
Works great now.
Post #525386 19th Aug 2019 12:31pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Henda wrote:
It's been about 11days since I diy fixed my aircon and so far it is performing great , only needing to go on a low fan setting to keep the car super cool , wife says it's too cold Rolling with laughter
Mines been ice cold since re-gassing in May, my wife moans it’s too cold also.
Very Happy 2004 Autobiography TD6 Java Black
Post #525430 19th Aug 2019 4:59pm
Wafoo81
United Kingdom 2005 Range Rover Vogue 4.4 V8 Barolo Black
Brian Considine wrote:
Wafoo81 wrote:
Groupon were doing a deal at £39 with ATS, if it's finished Kwik-fit do it all for £59, same thing pressure test, leak check and refill, saves the guesswork
About the same as a trained air-conditioning engineer charges (one who does not fit tyres).
Good luck with any Quickfords type outfits - past experience means none of my vehicles ever go there - not even for tyres (as it happens one of them jacked a vehicle of mine up using the floor pan !)
Would never use them for anything normally but heard good things about the air con on here so gave it a go, the bloke was fine, watched him do it all and he gave no flannel so for air con no issues
Post #525494 20th Aug 2019 7:26am
