Home > General > didnt know that |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35426 |
shall we have a poll on this.. ... - .- -.
2nd Mar 2011 12:26pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
My guess is that the distance between the front and rear wheels changes a little depending on the vehicle height, so lowering with your foot on the break will cause additional stress to the tyres, suspension and 4WD bits. I try to drop into access mode with the car in neutral and the hand brake off.
2nd Mar 2011 12:34pm |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
we were playing around with this last week on the LR experience afternoon. Clever bit of kit. Wan't aware it was on older cars?? FFRR TD6 HSE
2nd Mar 2011 12:39pm |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
manual says 'handbrake on' actually, to avoid confusion - from the manual 'access mode should only be selected whilst the vehicle is moving. In extreme circumstances, if it is necessary to select access height whilst the vehicle is stationary, 'N' (neutral) should be selected and the handbrake applied. Note that some noise from the suspension may be heard, accompanied by vibrations' |
2nd Mar 2011 12:43pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
On RRS TDv8 and S/C's it was also that that triggered the very trick dislocation of the rear antiroll bars so that the rear wheels would extend until they found the ground or ran out of extension (IIRC they could get another 5cm of extension beyond the super-extended mode on one rear wheel too!) I don't know if the S/C and 4.4TDv8 can do this as they also have a similar DR system to the TDv8 and S/C RRS's 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
2nd Mar 2011 12:46pm |
Presumably that’s to stop you rolling away. Following washing the inner wheel arches, I once lowered the car from off road height straight to access height with my foot planted heavily on the brake pedal, the suspension groaned a little, but when I took my foot off the car dropped like it had been dropped from a crane (albeit only about 2 inches) . When I got out the car I discovered the rear suspension was much lower than normal access height. I assumed this was because the suspension stuck at a particular height due to the brakes being applied, so more air was released than normal. I’ve not tried to reproduce this as I don’t want to break anything. Who's going to be the first to upload a photo or their FFRR at extended height then? Gone - Range Rover Supercharged 2006 |
2nd Mar 2011 1:01pm |
Extended height
6th Mar 2011 8:59pm |
looks good justin, and you can walk underneath and do repairs. ... - .- -.
7th Mar 2011 8:51am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1733 |
Being a complete numbnuts here as well. I assume the access mode being discussed is via the long button the drivers door forward of the window switches.
7th Mar 2011 10:55am |
Right button wrong method you should push it as you are driving into drive not while stopped |
7th Mar 2011 11:01am |
there's also the 3 mode knob on the dash that gives you access mode... ... - .- -.
7th Mar 2011 11:05am |
you, like the rest of us have got it wrong according to the handbook as i said earlier - given its not in BIG BLOCK LETTERS its not critical? i supposed its a case of RTFM |
7th Mar 2011 2:10pm |
