Home > General > didnt know that
shall we have a poll on this.. Laughing ... - .- -.
Post #52499 2nd Mar 2011 1:26pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
My guess is that the distance between the front and rear wheels changes a little depending on the vehicle height, so lowering with your foot on the break will cause additional stress to the tyres, suspension and 4WD bits. I try to drop into access mode with the car in neutral and the hand brake off.
Gone - Range Rover Supercharged 2006
Post #52505 2nd Mar 2011 1:34pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
we were playing around with this last week on the LR experience afternoon. Clever bit of kit. Wan't aware it was on older cars?? FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #52509 2nd Mar 2011 1:39pm
p-trax
Japan 2011 Range Rover Vogue 4.4 V8 Santorini Black
nick h wrote:
scarey wrote:
nick h wrote:
had a look in my manual and can find no reference?
but i did read that you should only select access height when the vehicle is moving!!!
i've selected it when stationary and in park Sad
any damage done????
thats what it says in the manual nick, but it can be done in extreme circumstances, then neutral is selected and the handbrake is on and you might hear noises and feel vibrations.
thanks Stan but numbnuts here has been doing it as a matter of course when stationary and in Park Sad
must have misread that part of the user manual
assuming as its not written in BIG BLOCK LETTERS i've done no damage - i did hear groaning a few times!
DOH, me too, for the last 5 years, on 3 cars! Gerry
____________________________________________
Arrived>Santorini/Jet FFRR MY11 TDV8
Gone>Stornaway/Ebony MY09 RRS HST TDV8
Gone>Java black/Ebony MY07 RRS HSE TDV6
Post #52513 2nd Mar 2011 1:42pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
manual says 'handbrake on'
actually, to avoid confusion - from the manual
'access mode should only be selected whilst the vehicle is moving. In extreme circumstances, if it is necessary to select access height whilst the vehicle is stationary, 'N' (neutral) should be selected and the handbrake applied. Note that some noise from the suspension may be heard, accompanied by vibrations'
Post #52514 2nd Mar 2011 1:43pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
On RRS TDv8 and S/C's it was also that that triggered the very trick dislocation of the rear antiroll bars so that the rear wheels would extend until they found the ground or ran out of extension (IIRC they could get another 5cm of extension beyond the super-extended mode on one rear wheel too!) I don't know if the S/C and 4.4TDv8 can do this as they also have a similar DR system to the TDv8 and S/C RRS's 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #52516 2nd Mar 2011 1:46pm
JustinP
Presumably that’s to stop you rolling away.
Following washing the inner wheel arches, I once lowered the car from off road height straight to access height with my foot planted heavily on the brake pedal, the suspension groaned a little, but when I took my foot off the car dropped like it had been dropped from a crane (albeit only about 2 inches) . When I got out the car I discovered the rear suspension was much lower than normal access height.
I assumed this was because the suspension stuck at a particular height due to the brakes being applied, so more air was released than normal.
I’ve not tried to reproduce this as I don’t want to break anything.
Who's going to be the first to upload a photo or their FFRR at extended height then?
Post #52523 2nd Mar 2011 2:01pm
JustinP
Extended height Cool
Sadly I did not manage to get it to super extended mode, none the less, it looks like a monster truck.
Post #53228 6th Mar 2011 9:59pm
looks good justin, and you can walk underneath and do repairs. Laughing ... - .- -.
Post #53266 7th Mar 2011 9:51am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Being a complete numbnuts here as well. I assume the access mode being discussed is via the long button the drivers door forward of the window switches.
I usually press this when I get home and stopped/in park so the wife can get out without jumping/or falling. (she's not that tall Laughing ). If so, then I'm also doing it wrong.! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #53282 7th Mar 2011 11:55am
Right button wrong method you should push it as you are driving into drive not while stopped Thumbs Up
Post #53283 7th Mar 2011 12:01pm
there's also the 3 mode knob on the dash that gives you access mode... ... - .- -.
Post #53284 7th Mar 2011 12:05pm
nick h
you, like the rest of us have got it wrong according to the handbook
as i said earlier - given its not in BIG BLOCK LETTERS its not critical?
i supposed its a case of RTFM Very Happy
Post #53324 7th Mar 2011 3:10pm
