Home > General > didnt know that
didnt know that
here's an edited post nicked from the rr.net forum..bloke got stuck in snow and was querying an extended height he had encountered..
You probably bottomed out after digging deep enough into that mud, the car sensed it and automatically raised itself to extended height, which is about 1.5" higher than regular off-road mode, to try and clear the obstacle. Once there, you could then invoke "super-extended" mode manually to give you a little - about 1" - extra clearance still, if necessary, by holding the suspensions UP button for about 3 seconds while pushing the brake pedal, until you hear the chime and see a confirmation message in the instrument cluster (you may have done so involuntarily.) That's as high as the suspensions will get, and indeed the car does look like it's on stilts. It will exit extended or super-extended mode automatically if you accelerate over 3/4 mph for at least 30 seconds, or you can return to regular off-road height by hitting the DOWN suspensions button.
You can simulate grounding by strategically (and carefully!) positioning a jack stand or similar object under the car in regular or off-road height and then, with the engine running and all door closed, lowering your suspensions to access height. The car will sense the obstruction as it lowers, and immediately raise the suspensions to extended mode to attempt clearing it. Works like a charm, and many owners of newer Land Rovers carry a jack stand with them when wheeling, specifically for that reason before negotiating sections of a trail that may require the extra clearance... You can't manually select extended height otherwise, the electronics must invoke it when they sense grounding. It's all explained in the often-overlooked Owner's Manual, air suspensions chapter...
Post #52469 2nd Mar 2011 12:27pm
dan_uk_1984
I have heard of this on RR.net in the past, I've never been able to find any info on it though.
It is not in the WSM or the Owners manual for 2002-2004, can you confirm it's in your 2005 scarey? Or anyone else with their manual to hand?
D
Post #52472 2nd Mar 2011 12:43pm
just looked dan and i cant find any ref to this... ... - .- -.
Post #52474 2nd Mar 2011 12:54pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Was it posted eleven months and a day ago? Laughing 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #52476 2nd Mar 2011 12:57pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
had a look in my manual and can find no reference?
but i did read that you should only select access height when the vehicle is moving!!!
i've selected it when stationary and in park Sad
any damage done????
Post #52479 2nd Mar 2011 12:58pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Yes I have experienced it in both the RRS's and this FFRR - super-extended offroad height. It is normally triggered automatically but you can also force the car to go into it without a jack under the car. If you look on RRSport and also IIRC JMC has posted about how to do it here as well. Also search on Disco3.
Of course you can select access height when moving, just not above 15mph IIRC, I select it every time I'm driving into my drive so the car is lowered by the time I have stopped. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #52480 2nd Mar 2011 1:01pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
It's in my 2006 manual Smile
And I was shown it during the LRE 1/2 day.
Gone - Range Rover Supercharged 2006
Post #52483 2nd Mar 2011 1:05pm
dan_uk_1984
I wonder what year this comes in?
The EAS was re-designed in 2007/2008? When they dropped the "motorway mode" from the EAS, I'd bet this is when this change was introduced.
The Classic and P38 both did the same, it was a shame to see it dropped on the L322. Although I do like the cross-link valves.
Post #52484 2nd Mar 2011 1:06pm
any damage done????
thats what it says in the manual nick, but it can be done in extreme circumstances, then neutral is selected and the handbrake is on and you might hear noises and feel vibrations. ... - .- -.
Post #52485 2nd Mar 2011 1:08pm
nick h
thanks Tim - but as i said i've been selecting it when stationary and in Park - which according to the manual you should NOT do!
my fault RTFM Very Happy
Post #52486 2nd Mar 2011 1:09pm
nick h
any damage done????
thanks Stan but numbnuts here has been doing it as a matter of course when stationary and in Park Sad
must have misread that part of the user manual
assuming as its not written in BIG BLOCK LETTERS i've done no damage - i did hear groaning a few times!
Post #52488 2nd Mar 2011 1:12pm
i've done it regularly as well mate. Embarassed ...now we know .. Laughing ... - .- -.
Post #52490 2nd Mar 2011 1:17pm
Tim in Scotland
I have lowered to access in N and P/ stopped on my drive and it does make some noises from the tyres, possibly being stopped and lowering/raising puts some additional stress on the suspension? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #52491 2nd Mar 2011 1:17pm
makes sense tim ,the tyres are probably trying to move laterally outwards putting strain on the air bags. ... - .- -.
Post #52493 2nd Mar 2011 1:20pm
dan_uk_1984
Embarassed I obviously need to re-read my manual. I didn't know this either!
Post #52495 2nd Mar 2011 1:22pm
