![]() | Home > In Car Electronics (L322) > Nothing illuminating with lights? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
bump Current stable:
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
LCM is in front of the bonnet pull and controls all the lights...
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Craig, Dan has two different L322 |
Correct have an 02 and 07 the 07 is the problem - is it on the same place on both? Current stable:
Certainly is Dan yes... 👍 |
Right update on this as I had a proper look in the dark when the light switch is turned on the light switch illuminated and the red hazard light comes on. The rheostat will control these just fine but I have nothing else... any ideas?
right thanks to mr Stevenson - I have fixed this - looks like there is a new fuse added 51 which wasn't on the early cars (or only fuse panel cover!) changed it and happy days! Current stable:
