Home > In Car Electronics (L322) > Nothing illuminating with lights?
Danwilderspin
Hi all so I originally posted my cluster didn’t illuminate but now have discovered it’s more than that nothing illuminates eg climate radio etc... where would you look at this is there a fuse that drives all illumination? I have just had a windscreen changed could it be linked to rain light sensor ? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #522504 22nd Jul 2019 6:54pm
Danwilderspin
bump Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #524547 12th Aug 2019 3:41pm
LCM is in front of the bonnet pull and controls all the lights...
Didn’t think an 02 had an auto light sensor?
Post #524549 12th Aug 2019 4:14pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Craig, Dan has two different L322 Wink Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #524550 12th Aug 2019 4:26pm
Danwilderspin
Correct have an 02 and 07 the 07 is the problem - is it on the same place on both? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #524553 12th Aug 2019 4:47pm
Certainly is Dan yes... 👍
Post #524554 12th Aug 2019 5:20pm
Danwilderspin
Right update on this as I had a proper look in the dark when the light switch is turned on the light switch illuminated and the red hazard light comes on. The rheostat will control these just fine but I have nothing else... any ideas?
I had a fault in the cluster of ‘lost communication of lighting control module (front)’ any ideas now? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #525595 20th Aug 2019 8:52pm
Danwilderspin
right thanks to mr Stevenson - I have fixed this - looks like there is a new fuse added 51 which wasn't on the early cars (or only fuse panel cover!) changed it and happy days! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #530311 8th Oct 2019 1:56pm
