Home > Technical (L322) > Rear window washer not working |
roblane65 Member Since: 01 May 2017 Location: Newcastle Upon Tyne. Posts: 83 |
I've a similar problem myself ! wiper and washer were both working and I got the usual knock knock knock and the wiper was stopping in the middle of the screen . So I pulled it apart and sure enough the teeth were worn on the white plastic cog
11th Aug 2019 1:45pm |
Frexan Member Since: 15 Sep 2017 Location: Stockholm Posts: 4 |
My best guess at this point is the controll chip in the actual motor. Since i couldn't locate any specific relay for this function. But maybe it could be the Body Control Module... As i understand it, this is also a part of the electrics for wiper and washers.. |
11th Aug 2019 1:51pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Take a look at this https://www.fullfatrr.com/forum/topic50730.html
11th Aug 2019 5:37pm |
Thanks! The thing is I think there's something wrong with the electric. I connected the rear washer pump direct to 12v and it runs fine. But it doesn't respond to "normal" start (pushing the wiper-leaver forward). i.e i can't get a washer signal from the drivers seat to the back off the car... |
11th Aug 2019 6:16pm |
