![]() | Home > Technical (L322) > Front suspension bottom arm bushes and ball joints - FIXED |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Having now got my MOT old fatty has developed a massive knocking on the front end. Ive had a look underneath today, it's not the drop links, that was my first port of call, it looks like its the bushes in the rear of the two arms that have rotted away, it is making quite a solid thud.
But apart from:-
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 756 ![]() ![]() |
Personally I'd go for option 3, when I did mine on my first one I recall that the whole arm wasn't much dearer than just the bush. This made the job simple and pretty painless, I then had the bushes replaced at my leisure in the arms that I had removed, this gave me a "new" set for the next time. These bushes almost seem to be a service item. |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
I might have been a bit harsh on them, surley they have a purpose on some or other application.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2645 ![]() ![]() |
The Lemforder bushes that I fitted to mine exactly 1 year ago didn't last 20K kms. The originals were already on their way out when I purchased the vehicle at less than 20K kms but I put up with the knocking and wandering steering especially under braking for 3 more years. I'm not prepared to change bushes every 20K kms so I've ordered Polyflex bushes. Quite some years ago my son fitted the same brand and purple (road) versions to a Saab 9000 in the same position to overcome torque steer after an engine remap. The bushes did not increase harshness or noise or have any other adverse effects so I'm hoping mine will be similar. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
As I understand, the original design has rubber 'spokes' which crumble under braking weight of the FF.
The internal bump-stop prevents most of the braking movement - its the wheels pulling forwards with drive that stresses the upper and lower attachment links. I suspect that non-smooth surfaces such as gravel roads is the cause of mine's short life. |
Thanks guys, I feel an Island 4x4 order coming on for the front and rear arms with bushes. BMW i3 Electric Car
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
I knew that I had a similar issue when I purchased my l322 last month.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Option 1 here |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
I have had poly bushes (usually Power-flex) fitted to a few cars over the years and never had an issue with them They do vary in hardness and fitting excessively hard ones on a road car is definitely not a good idea.
GDM, your early feed-back would be appreciated. |
+1 also, where do you get your bushes from? BMW i3 Electric Car
Frexan Member Since: 15 Sep 2017 Location: Stockholm Posts: 4 ![]() ![]() ![]() |
Go for nr 3! just did this on my L322. Complete kit for both side was cheap (order from UK), and it's an easy job for your local mechanic. |
