Home > Technical (L322) > New L322 owner . Air suspension Woes.
m666blp
Hi. I have today purchased a 2003 Tdv6 l322 which has been sat for app 12 months .
It has been looked after well in the past and had a new gear box fitted shortly before it was parked up.
I fitted a new battery and it fired up straight away.
No suspension movement at all & Inactive suspension warning on dash .
I could really do with some advice .
What is my first port of call to diagnose the suspension issue?
Post #524202 8th Aug 2019 9:50pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
After battery change you need to reset the suspension. With engine running turn the steering wheel all the way to the left and then all the way to the right - the suspension will reset and the lights go out.
Plenty of information in the Wiki for all the things you are about to likely encounter! Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #524203 8th Aug 2019 10:31pm
m666blp
Many thanks .
Post #524214 9th Aug 2019 9:03am
DrRob
Research and find a good local independent LR specialist who are tried and trusted. Search on here and on the sister forums especially the Disco 3/4 one. There is bound to be one or two near you Thumbs Up
As above, the Wiki area on here is a god send as is the "search" function....some folks are lazy and don't bother using either before posting (not you!) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524215 9th Aug 2019 9:20am
m666blp
Thanks . There are a couple of good local specialists which I use where necessary. I like to do the majority of the mechanical work myself, unfortunately time pressures etc hinder progress , I’m sure this is the case for most people though.
I recently put my 110 dc on a new galv chassis and brought it up to a more purposeful specification.
The overfinch & evoque tend to go to the main dealers though , but I will hopefully get some time to take a look at the l322 , they are all pretty similar underneath.
Looking to just use it as a general hack & tow vehicle around and about the area and possibly for my son to learn to drive in , we’ll see how it goes , if it keeps raining like it is today I may yet trade it in for a boat .
Post #524217 9th Aug 2019 9:55am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Does the compressor run at all?
Can I also suggest you fill in your vehicle profile - I know it's in the first post but it makes it easier as the thread grows & for new threads. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #524232 9th Aug 2019 11:38am
m666blp
The compressor does not appear to work at all . I have reset with lock to lock and still message and no light on suspension switch . Fuse is good .
I may try to fire up the compressor separately, it has been sat for a while .
Post #524236 9th Aug 2019 11:54am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
is it right down on the stops
mine was on the stops when i bought it
i bought a icarsoft unit and cleared the faults and up it came
i still had suspension inactive or what ever it says but it was nothing to do with the suspension and the suspension was up and working RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #524248 9th Aug 2019 12:49pm
m666blp
Yes , right down on the stops . 2003 tdv6 vogue
Post #524253 9th Aug 2019 1:10pm
Any orange lights around the height selector ?
If none, then you have a hard fault, which will need diagnostics to clear it .
Post #524254 9th Aug 2019 1:24pm
m666blp
No lights on suspension switch at all .
I’ve booked it in for a scan with Richard at Trojan on Monday, at least
then I’ll know for sure .
Muchos gracias 2003 tdv6 vogue
Post #524257 9th Aug 2019 1:42pm
m666blp
So I took it took Trojan and they cleared all the faults and away it went again Smile .
I'd temporarily put my defender battery on as the original was super flat and needed a long old charge .
Unfortunately the defender battery did not have enough AH and over night the hard faults appeared again.
Original battery is now on a long charge and I will pop back again to get faults cleared again .
Suspension is up to normal weight and is staying there. Going to go for an mot next.
They are a big ole bus to drive. 2003 tdv6 vogue
Post #525274 18th Aug 2019 4:06pm
You need to know what the hard faults are, there could be a problem ? .
Post #525282 18th Aug 2019 4:43pm
knares
you need your own scan tool RR 2005 4.4 petrol
Post #525326 19th Aug 2019 12:56am
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
Get a good battery they misbehave badly with current drops
Post #525330 19th Aug 2019 6:49am
