Home > Technical (L322) > New L322 owner . Air suspension Woes. |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
After battery change you need to reset the suspension. With engine running turn the steering wheel all the way to the left and then all the way to the right - the suspension will reset and the lights go out.
8th Aug 2019 10:31pm |
m666blp Member Since: 08 Aug 2019 Location: cumbria Posts: 10 |
Many thanks . |
9th Aug 2019 9:03am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Research and find a good local independent LR specialist who are tried and trusted. Search on here and on the sister forums especially the Disco 3/4 one. There is bound to be one or two near you
9th Aug 2019 9:20am |
Thanks . There are a couple of good local specialists which I use where necessary. I like to do the majority of the mechanical work myself, unfortunately time pressures etc hinder progress , I’m sure this is the case for most people though.
9th Aug 2019 9:55am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
Does the compressor run at all?
9th Aug 2019 11:38am |
The compressor does not appear to work at all . I have reset with lock to lock and still message and no light on suspension switch . Fuse is good .
9th Aug 2019 11:54am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
is it right down on the stops
9th Aug 2019 12:49pm |
Yes , right down on the stops . 2003 tdv6 vogue |
9th Aug 2019 1:10pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Any orange lights around the height selector ?
9th Aug 2019 1:24pm |
No lights on suspension switch at all .
9th Aug 2019 1:42pm |
So I took it took Trojan and they cleared all the faults and away it went again .
18th Aug 2019 4:06pm |
You need to know what the hard faults are, there could be a problem ? .
18th Aug 2019 4:43pm |
you need your own scan tool RR 2005 4.4 petrol
19th Aug 2019 12:56am |
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 |
Get a good battery they misbehave badly with current drops |
19th Aug 2019 6:49am |
