![]() | Home > Technical (L322) > TDV8 whistle |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
No, I still have the noise. It sounds like a rattlesnake at the moment.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Manifold stud snapped ![]() |
Bogi 6357 Member Since: 28 Jul 2019 Location: Scottish Borders Posts: 54 ![]() ![]() |
Took for a diagnostic appointment and landrover have diagnosed the right hand turbo to be leaking at intake , I’m presuming
Paulie m Member Since: 21 Dec 2020 Location: Greater Manchester Posts: 4 ![]() ![]() ![]() |
Hi I'm having the same whistle noise did you sort it or find out what it was c |
Replaced turbos oil feed pipes and turbo intake pipe on drivers side
Cheers Ian for replying im going take mine in for diagnostic bet its going be a costly job did you just replace 1 turbo or both a guy told me replace both why the body s off |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Take it to someone who knows what they are doing...... the body does not come off a 322..... sport, yes, 322 no. There is nothing that can't be fixed with a hammer😜😜
Hi mate I've got the 3.6 tdv8 sport unfortunately 😕 so a body off job if found to be turbo |
I replaced both and all the oil feed pipes on L322 , I think if you are paying a days labour to have the body removed on your sport , probably be as well doing both mate Kind Regards Ian |
If the body is coming off, then it makes sense to have as much done as is sensible.
RosieL322 Member Since: 20 May 2021 Location: County Durham Posts: 26 ![]() ![]() ![]() |
Would you share how much this cost please? I’m just trying to get an idea of worst case before I spend a small fortune on fully servicing mine. I have a whistle on acceleration too ☹️ |
Is the turbo whistle a guaranteed sign you are about to experience financial ruin? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Listening to the whistle in the videos, this is quite a distinct sound. Did the pipe replacement sort the issue? I'm surprised there wasn't any soot caused by that.
