![]() | Home > Maintenance & Mods (L322) > Re-mappng |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 ![]() ![]() |
this thread is a bit old but should have the info you need,
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
we had a K&N in our 07 4.2 SC, caused no end of issues, the oil was coming off and hitting the sensor causing running issues,
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Ford Hill, Wirral. Not Merseyside Posts: 554 ![]() ![]() ![]() |
I'm thinking of leaving the original filter boxes in ace and fitting the k&n replacement higher flow unit to avoid that exact scenario.Wont do much except Improve flow slightly. |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 329 ![]() ![]() ![]() |
The drop in K&N is also an oiled filter and can cause issues with Air flow sensor 4.2 SC - sold , now bought back
Interesting.......I had one in my previous 4.2SC and didn't have one single problem???.. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 ![]() ![]() ![]() |
Why on earth do you feel you need your 5.0 remapped sir? They are not slow in normal guise... are you sure the thing is running right to start with? |
Vanity Sir...pure vanity. Blondie runs and drives and handles and pulls as if it was one day old.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 ![]() ![]() |
I must admit, I want to up the output of mine, however despite no untoward noises thus far, I will probably upgrade the chain tensioners and followers first for peace of mind.
I am also sorting that too. Fortunately my son is a Merc Technician, so he will be getting that bit done. That will save a bundle. AND be done properly! Then the re-map.
That’s useful! Keep the costs down to just “eye watering”
It will still be ball extractingly costly. He will want lots and lots of beer tokens! |
Drat!!
He is very very good to be fair. Unless i'm doing it, I won't let anyone else touch it. He did almost all the work on my previous one. Only thing he couldn't do was have it sit on the company ramp for 2 months !!!! Tony
Rare to find a really decent actual mechanic, rather than a gonk that just blindly follows the DIS. Formerly happymadison1978 |
