Home > Technical (L322) > To Flush or Not to Flush??
MadL322
United Kingdom 2002 Range Rover HSE 4.4 V8 Cairns Blue
2002 4.4V8 - 107k on the clock. Flush then new gearbox oil, or empty, fill, run, then empty and fill again?? Suggestions from a tech point of view appreciated
Post #523857 5th Aug 2019 10:00pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I’m a believer in drain fill, drive 500+ miles, drain and refill.
Jim
Post #523858 5th Aug 2019 10:11pm
MadL322
ok, all well and good, although garage doing for me so thats "115 x 2 which I guess is cheaper than a new gear box in time lol. Would you only replace the filter once, or on both occassions?
Post #523859 5th Aug 2019 10:26pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
any flushing better than none at all but getting the fluid as clean as poss can only aid the longevity of the gearbox , id do a filter each time unless the gear oil still looks near enough new ?
Post #523866 6th Aug 2019 7:04am
