Home > Maintenance & Mods (L322) > Park not selecting properly for ign start |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
If I reselect park or hold in place I can start the car , so Can someone explain how I can adjust the cable so that Park is selected in the proper position. It just seems that the lever is slightly out of sync.
31st Jul 2019 5:34pm |
Thanks . .. WM ?
31st Jul 2019 7:50pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Might just be the drive selector cable needs lubricated, common problem.
31st Jul 2019 7:57pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Sorry, WM = workshop manual.
1st Aug 2019 10:04am |
Thank you , one of my starting problems have been resolved when I thought I was changing to a better battery , but not so , it was down in power but not in volts so was a no go' er.
1st Aug 2019 6:20pm |
Preaching to the converted I know, but for god''s sake, be careful while under the car.
2nd Aug 2019 9:06am |
Thanks , yeah was a bit wary , I had it on ramps without engine on of course , the cable has improved vastly. Unfortunately the changing of the battery has upset the suspension, and it has dropped at the front and does rise , but falls again , have spent time with it but it must be needing a reset or something. |
2nd Aug 2019 6:26pm |
No further forward , Rr on its knees now and will not get up . Back to battery I reckon first .? |
2nd Aug 2019 10:42pm |
I just spent two hours with the suspension set ups on Gap and really no further forward. I ended up with all four levels on the bottom and wouldn’t raise , one side , the left side had been an inch lower . That maybe insignificant so took the car out ,( it does say no faults at the moment ) and when I got back the rear is up but not the front , got out shut the door and the rear went up another half inch .
3rd Aug 2019 11:54am |
I moved my new. Problem to Technical forum |
3rd Aug 2019 2:29pm |
Park problem back again !
14th Aug 2019 4:36pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Take it to Mikey at MMP in Dundee Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Aug 2019 4:45pm |
I would try copiously oiling the cable again and the various pivots on the actuator arm and work the drive selector backwards and forwards a lot and see what happens. |
14th Aug 2019 6:30pm |
Thanks , I think after the previous owner , almost 3 yrs ago this sticky cable feature may have started then, I will investigate the travel of the actuator , without the engine running ! |
14th Aug 2019 7:45pm |
