Home > Technical (L322) > sat nav |
PLUMBERMAN Member Since: 15 May 2009 Location: widnes, cheshire Posts: 12 |
can i ugrade my sat nav to have speed cams etc ,its a 54 plate with touch screen ? |
1st Mar 2011 5:43pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
nope....but you can buy an inforad k1 for £20 [discussed in off topic section] ... - .- -.
1st Mar 2011 5:44pm |
thanks , will have to save up for newer rangie! |
1st Mar 2011 5:46pm |
i might be wrong but i think that using the bmw system some how you can load speedcams but this is only for the pre touch screen.. ... - .- -.
1st Mar 2011 8:09pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
thats right,the good old bmw system will let you have them V8 facelift Range Rover Autobiography 22" wheels.
1st Mar 2011 9:51pm |
p-trax Member Since: 30 Dec 2010 Location: Hertfordshire Posts: 261 |
Is this just LR being behind the times, a technical limitation, or LR not have fully identified a way to update/ charge for th new data.
1st Mar 2011 10:16pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Denso make the Nav units and Navteq make the maps and quite a few manafacutrers buy in this solution so it's not such a unique problem.
2nd Mar 2011 7:31am |
its the average FFRR owner having the knowledge of 'how' to put the speedcams onto the sat nav..tomtom and garmin are easy cos you just connect the unit to the pc/laptop and download, how do you do that with the RR unit?..the only way i can think of is to copy the speedcams onto a cd disc and load them via the dvd unit as a kinda firmware flash....but could this be to technical for the average driver. ... - .- -.
2nd Mar 2011 8:30am |
And the latest models have no disc, not sure they have a hardrive or solid state memory that is updated? Gerry
2nd Mar 2011 9:04am |
does yours possibly have an sd card with the map data on gerry.. ... - .- -.
2nd Mar 2011 9:07am |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
More recent cars also have a USB reader in the centre cubby that might be useful as that is also read by the head unit.
2nd Mar 2011 9:43am |
wouldn't be a legal reason because tomtom actively promote downloading [at a price] speedcam data and for many countries i any add... ... - .- -. Y. O. L. O. . |
2nd Mar 2011 11:10am |
not sure, dealer suggested it was a hardrive, but that could be a guess as he also stated there was no current upgrate/update path defined. i assume that a connector exists somewhere to upload the data. *off topic* WRT the USB connector, I asked if this could be used for video, and was told that port is read for MP3 data only. again smells of BS and a lack of tech knowledge from the dealer. maybe not as standard, but the head unit can clearly decode a video signal. I do not have the rear entertainment system in my car, but as the head unit has a "dvd" button on i assume also i could add an aftermarket player to feed the head unit. (not sure if this would need a new/ additional wiring loom?) to all intents and purposes the digital TV is useless, and I feel that as such the dual view screen i have is just a gimmick. would love to be able to send a video signal to it to at least then serve a purpose Gerry ____________________________________________ Arrived>Santorini/Jet FFRR MY11 TDV8 Gone>Stornaway/Ebony MY09 RRS HST TDV8 Gone>Java black/Ebony MY07 RRS HSE TDV6 |
2nd Mar 2011 11:37am |
