Home > Technical (L322) > Access mode.....
Anvil
Access mode.....
Hi All,
Not a problem at the moment, everything still works! My question is around whether people tend to use the access mode all the time or avoid it? I'm a bit of a short arse, and I reckon I'll put less wear on my seat bolsters getting in and out with the car sat on its haunches, so I use it all the time. Am I likely to cause myself a propblem further down the line with air bags or compressor?
Is it better to use this kit and keep it all freely moving, or better to just rest it all until its really needed?
Cheers!
Post #523175 29th Jul 2019 12:51pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
I have had a number of vehicles since my first P38A with air suspension and virtually always lower it. In fact, in my L405, I have selected the option to auto lower it when a door is opened. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #523182 29th Jul 2019 1:22pm
Weegie
I use it all the time. Smile John
GAP iiD BT
Post #523187 29th Jul 2019 1:48pm
DrRob
Every time to avoid seat bolster wear Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #523193 29th Jul 2019 2:47pm
Anvil
Thanks All,
Makes life a lot easier when you're only 5'8". I need a step ladder for the boot! Wink
Post #523195 29th Jul 2019 3:06pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I use it all the time. However, if a door is opened whilst lowering then the lowering is stopped. I though it was a "safety" feature, to prevent lowering of door onto an external object. Is that not the case with the L405?
Post #523203 29th Jul 2019 3:41pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
All the time coz of my little pins Rolling with laughter
Plus for me if it's used it's being exercised same with sport mode manual and low ratios and modes every now and then Thumbs Up
Post #523212 29th Jul 2019 5:00pm
Anvil
That’s what I figured. In my experience mechanicals seem to prefer to be used. Trust me, I used to drive a TVR!
Post #523222 29th Jul 2019 6:28pm
GGDR
Quote:
...in my L405, I have selected the option to auto lower it when a door is opened.
Can you do this on a 322?
. Cheers, Greg
Post #523225 29th Jul 2019 6:52pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I lower it pretty much every time. Makes getting in and out easier. Although I’m vain so it’s probably more to do with looks
Post #523227 29th Jul 2019 7:10pm
Nick591
I lower mine most of the time, for seat bolster preservation, wife finds it easier to get in, and to help the dog jump up into the back! I also have side steps which help a lot with the first two as well. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #523245 29th Jul 2019 8:41pm
ianmacd
Thats how it used to work on all my previous ones but there was an option in the vehicle settings (I think) that allowed easy access or something. I actually thought it was moving the wheel away and seat back wen the driver gets out but it seems to lower the vehicle when a door it opened.
My L322 used to stop as soon as a door was opened as I used to moan at SWMBO always opened it while it was lowering despite me telling her 1 billion times not to Sad
I am 99.999% sure you can not. Current: RR L322 2010
Post #523249 29th Jul 2019 9:18pm
Full Fattie
On an l322 it shops when the door is opened but resumes when it is shut
Post #523284 30th Jul 2019 9:47am
Paul thornton
I used to lower mine every time I parked it because it looked better!
The Mrs didn't however so I used to find myself going out and hitting the button whenever she parked it! I even lowered my access height a little more using an IID tool.
Obviously it will put more wear on the compressor but I think it actually does the airbags good not to be in the same position all the time.
Post #523305 30th Jul 2019 12:48pm
Anvil
Great! Thanks folks... Looks like I'll continue to use as normal then. Very Happy
Post #523309 30th Jul 2019 1:14pm
