Home > In Car Electronics (L322) > Touchscreen Frozen Locked Knob light flashing orange 2006
Page 3 of 3 <123
link sorted thank you Thumbs Up ... - .- -.
Post #449372 28th Aug 2017 8:09pm
jaylow
Germany 2007 Range Rover HSE 4.4 V8 Causeway Grey
Hi, im from germany and my english is not so good... I have a Range Rover Sport 2007 and the same problem with the Touchscreen Freeze. There is still the green Land Rover logo and radio works but WITHOUT sound. There is no Sound and in the Touchscreen still the Land Rover Logo.
I need help please.
Post #477441 3rd May 2018 4:29pm
hi jaylow...
this forum is for the bigger range rover....
we have a forum dedicated to the sport here,
http://www.rrsport.co.uk/forum/
but, try a battery reset.. ... - .- -.
Post #477443 3rd May 2018 4:34pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
I think i've also been plagued, since wednesday, by the frozen screen issue.
I've tried the solution here but nothing happens.
I tried putting both cables end to end, so that they are touching each other and also with a connector to hold them ''looking at each other''. and nothing happened.
well... no entirely true...
When I put them together, i can hear a lot of noises coming from the systems on the back, like zzzzttttt, pppfffff, tttccchhhhh, but the screen remains frozen.
Plus, i only see light, on one of the cables, the one that goes into the module. the other (i think its the return cable) its dark.
So... Any ideas? advices?
Post #503595 1st Feb 2019 5:34pm
mohammed abood
United Arab Emirates
Hi everyone,
I have a 2012 l322 sc and I have the same problem frozen screen with the land rover logo on it and blinking power button. I have checked the fuses and reset the battery but no Terminal touching each other or as called hard reset but still no use.
I've tried the optical cable shortening from the bluetooth module using the same principal of the video shown earlier but using the same socket for both ends..... check YouTube, but still nothing .....dead end as usual.
Plz need desperate help nothing is working out helpppppp plzzzzz Big Cry
Post #513917 1st May 2019 10:51pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
northernmonkeyjones wrote:
Just as an addition, there is an input fibre optic and an output fibre optic in the plug, just worth noting which is which for when you come to reinstall the Bt module.note the directional arrows on the bottom of the connection plug. Thumbs Up
excellent write up
i made this mistake, still trying to find which fiber optic goes where RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #522872 26th Jul 2019 3:19pm
Steve RR
Scotland 2011 Range Rover Vogue SE TDV8 Fuji White
Humm, I am the same as VMPP above. Connected the 2 from the Bluetooth together and a lower down Ecu starts making noises, just as it does when I plug the 2 back into the BT unit, so can I assume that the BT unit is ok and passing the signal through? I have done power resets etc, so what can I try next?
Thanks folks.
2011 D4
2007 TDV8 FFRR
4.6 P38 Autobiography
300Tdi county 110
Too many late Classic RR to count
Bowler Tomcat Smile
Post #588223 21st Mar 2021 10:40am
Page 3 of 3 <123
