Home > In Car Electronics (L322) > Touchscreen Frozen Locked Knob light flashing orange 2006
Page 2 of 3 <123>
Katash, if there is a break in the fibre optic chain anywhere then its the same result... Thumbs Up
Post #248601 16th Mar 2014 11:29am
smiledoc
United States 2006 Range Rover Supercharged 4.2 SC V8 Chawton White
My guess is that 95% of those suffering with this problem will never replace the Nokia unit. Really no need to. I was very careful not to excessively bend the two optic cables. They are fairly thick and probably pretty tough, but why take the chance of breaking them?
To my knowledge, my Nokia unit has never been exposed to any sort of moisture. I believe that they are just poorly engineered and have cost Land Rover customers thousands of dollars and untold anguish trying to track down what's causing their touch screen functions to lock and fail. It's also no doubt cost Land Rover thousands in wasted time trying to figure it out. I know from this Forum and other LR forums I've researched, not even the dealerships have a clue as to what the cause is, nor how to fix it. Now we know...now we have a 5 min. "do it yourself" fix that anyone can do themselves. Maybe someone at Land Rover will read this and pass it on to the dealerships as a service bulletin.
PS: After I made the photos, I decided the loop was too big, so I went back and cut the Bic pen plastic down to about 1- 3/4 inches. It worked just the same but made the loop more manageable (not so large)
Post #248645 16th Mar 2014 4:34pm
Semperfidlas
England 2005 Range Rover HSE Td6 Zambezi Silver
Hi
Tried this bypass today after my touchscreen went dead and it worked a treat all back to normal except for phone/Bluetooth,
Is it just a case of me buying a new phone/Bluetooth module to reinstate the Bluetooth?
Post #310865 5th Feb 2015 2:45pm
i would try a battery reset first.. ... - .- -.
Post #310879 5th Feb 2015 3:43pm
Brydo
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
Would this work on a 04 vogue td6. The Nokimod
smiledoc wrote:
Since I just joined today, I'm not sure how to share this across the board. Feel free to repost this fix in whatever forum area will help the most people. Thanks!
Post #386942 13th May 2016 9:11pm
No, only works for the later touch screen cars...
Welcome aboard... Start your own thread with your problem, someone will help... Pete
Post #386947 13th May 2016 9:30pm
Thanks for sharing smiledoc ! Thumbs Up All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #386987 14th May 2016 7:13am
Brydo
Thanks for your reply my 04 rr vogue has touch screen, sat nav, dvd, and cd, changer. I have 2 photsos of rear compartment and a fiber optic cable plug if someone could help me workout what is what inthe pics
Post #387021 14th May 2016 10:02am
Brydo
I have done the loop fix on one fibre optic cable that had the plug attached but not plug into anything, any info would help
Post #387040 14th May 2016 11:07am
Yours must be one of the first 05MY then... Thumbs Up
Don't really understand what your asking...
What doesn't work, exactly what have you done and where, and what happened when you did it...??? Pete
Post #387043 14th May 2016 11:12am
Brydo
My touch screen has froze with just the range rover logo so I have no radio, satnav dvd or cd. The photos show the rear compartment and fibre optics, and one optic plug that was attached to the 2 fiber optic cable that I have joined in a loop ( the plug was not linked into anything before removal from cables and loop fix tried). There is no bluetooth modulebut I believe there may have been but has been removed as there is a phone dock in the centre consoul. Hope this makes some kind sence
Post #387052 14th May 2016 11:54am
If it was working and now doesn't then it's not the lack of a bluetooth unit as it wasn't there anyway..
Must be failure of one of the units in the system somewhere... I'm afraid I don't know enough about the later units to help, I suggest you start your own thread on your problem, you will get more help that way than dragging up a very old thread... Thumbs Up Pete
Post #387063 14th May 2016 2:00pm
Nick babs
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Brilliant post just fixed mine by using this method
Thank you [/quote]
Post #425096 27th Jan 2017 7:09pm
TimP
England 2005 Range Rover Vogue Td6 Java Black
Thanks for this.... just had to do mine as bluetooth unit failed in the last week. Without this wiki/thread/forum, I would not have had a clue what the problem was or how to sort it.
Tim
Post #433477 1st Apr 2017 4:54pm
gizze
Just a heads up, the wiki link for this article does't link back to this thread btw. It links to a headlight removal thread.
One thing to take note of, you really need to unplug the unit too, if you don't it doesn't go to sleep and draws a lot of power, around 1.2 amps, and will kill your battery pretty quickly.
Also, the TMC module is on the same fuse (number 27 from memory) and I found that this was also not allowing the car to sleep properly.
I went from 1.2amps when the car slept with the faulty bluetooth and tmc still plugged in, to 0.6amps with the bluetooth unit then unplugged (power and can connector not just most ring) and with just the TMC module connected down to 0.02 amps. and that was with the fuse out, that probably didn't matter but thought may as well as nothing on that ring any more.
So from around 4 days before a flat battery (and approx 24 hours for transmission and suspension errors etc. on start up) to what should be in theory more like 6 months (in theory). Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #449365 28th Aug 2017 7:17pm
Page 2 of 3 <123>
