Home > Maintenance & Mods (L322) > Faux low coolant level warning 4.4 TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
It could simply be that the float switch in the header tank has got stuck, or
25th Jul 2019 8:22pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
Could be the float stuck however the old wives tale of specific gravity of the coolant being low is never going to be the cause. The sensor is a magnetic reed switch that never comes into contact with the coolant. My experience with the earlier cars shows the exciter magnet, or whatever is within the float to switch the magnetic reed switch loses its power, the only reliable remedy is a new expansion tank if that is the problem 2007 TDV8 VSE
26th Jul 2019 12:33am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
TDV8_Tommy,
26th Jul 2019 8:37am |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 397 |
Thank you all, very helpful.
26th Jul 2019 12:09pm |
Ignore my last post... 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
26th Jul 2019 12:10pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Mine is starting to do this
15th Nov 2022 7:04pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1463 |
Replacing the air con compressor doesn't involve disturbing any of the cooling system.
15th Nov 2022 9:39pm |
