Home > Maintenance & Mods (L322) > Rear sub frame bushes
SteveRRL322
Good Afternoon Guys,
The back end of my Range seems to be feeling a bit more wobberly than usual. I’ve had a look underneath
At the rear sub frame bushes as the car is now 12 years old and I wondered if you thought they looked knackered?
Yes they look a little bit torn but is this normal?
What do you think? Anything else I should be looking at?
Thanks for looking,
Steve.
Post #522276 20th Jul 2019 12:53pm
a) are the MOT people saying anything ?
b) Do you want to put yourself through this:
TD6 '02 FFRR Rear Subframe Bushes Replacement
I do have the big and small metal tubes, and the metal plate with centre hole available for a price, but you would need your own bush pressing kit. .
Post #522281 20th Jul 2019 1:58pm
SteveRRL322
Saled through last mot in December no problems.
Looks a heavy job so would proberly pay someone if it needed doing.
Post #522283 20th Jul 2019 2:12pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
It's hard to imagine you'd feel anything significant from the subframe bushes other than a few clonk noises if worn like that.
If it feels that noticable, it's more likely to be the rear hub bushes or toe control arms. Have those been looked at / checked with a pry bar? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #522290 20th Jul 2019 2:53pm
SteveRRL322
No knocking or clonking.
What do rear hub bushes on there way out feel like?
Cheers
Post #522291 20th Jul 2019 3:01pm
Pawl
they can feel like the car is steering itself from the back as the rear wheel camber changes. Its what was happening on ours before I changed the hub bushes Paul,
Post #522292 20th Jul 2019 3:13pm
