Home > Technical (L322) > Restricted Performance fault TDV8 4.4
Page 2 of 4 <1234>
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Problem is still there and without the engine cover on I reckon I can hear a whooshing on acceleration along with a P006A Manifold Pressure fault so suspect a leak in a hose.
Couldn't hear anything with the bonnet up and revving engine but maybe that doesn't create enough load to spin up the turbo properly.
Are the intake rubbers and intercooler hoses a LR only part or are there other suppliers?
Cheers,
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #522100 18th Jul 2019 12:24pm
GraemeS
I made my own intake hoses from 70mm ID black silicone hose - each 55mm long. I re-used the original clamps.
Post #522101 18th Jul 2019 12:34pm
mm289
Awesome, thanks Graeme, just ordered some up so I can fit over the weekend. Even if it isn't the boots leaking the FF has done 90k now so going to go soon anyway Laughing
Cheers,
Paul. 2011 TDV8 AB
Post #522103 18th Jul 2019 1:00pm
Baltic Blue
Dirty black soot is usually found near the split.
If you wipe them over with a piece of clean kitchen paper roll, you might find the leak.
Post #522106 18th Jul 2019 1:08pm
nino_nino
nice tip Mike, Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #522110 18th Jul 2019 1:51pm
Westminster_Bri
I had a split in one of mine a couple of weeks ago, exactly the same issue and the split was right under the jubilee clip. I 'tweeked' the jubilee clip and managed to get her going again for another week until I could get the part. (low revs with minimal boost).
I got Britpart replacement parts, much thicker braided type rubber that appear far more durable than the original LR Part.
As I was replacing one, I figured I would replace all four whilst I had it apart. Took about an hour and a half all told.
Post #522142 19th Jul 2019 6:49am
mm289
Good tip Mike - I will try that.
I think it is probably a hose rather than the CSOV as it is now happening at low revs. Had to nurse it back round the M25 last night as it was OK at 70 if on light throttle but as soon as you tried to accelerate it popped the error Rolling Eyes
Had the IID in and was resetting the fault code evry so often Laughing
So, silicon tube arrives today so I will get under the hood with some kitchen towel and see what I can find!
@westminster_bri it might be worth linking to where you found the Britpart replacements for anyone else thats looking, I looked on the ususal suspects and couldn't find any Question
Cheers,
Paul. 2011 TDV8 AB
Post #522143 19th Jul 2019 6:53am
DrRob
Was it these? Doesn’t say if it is for 3.6 or 4.4 Whistle
https://www.britpart.com/parts/performance...ses/da4580
https://www.island-4x4.co.uk/silicone-hose...34045.html
Perhaps they fit both? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #522144 19th Jul 2019 7:07am
Westminster_Bri
I'm assuming we are talking about the same parts here...
https://www.britpart.com/non-accessory-parts/lr056285
Post #522151 19th Jul 2019 8:46am
mm289
@DrRob - those are for a 3.6 not 4.4 unfortunately Smile
@Westminster_Bri - those look like the right part for a 4.4, would require 4 off Thumbs Up
Cheers,
Paul. 2011 TDV8 AB
Post #522153 19th Jul 2019 8:52am
Westminster_Bri
Yup, and pointed out in the pic below (apologies for the crude mark up!) - Came in at £24.75 each
Post #522154 19th Jul 2019 8:58am
Baltic Blue
Silicon 70mm x57mm couplers are available on eBay,
Sorry can’t seem to attach a direct link, but just search 70mm silicon hose.
Mike
https://rover.ebay.com/rover/0/0/0?mpre=ht...1121422504 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #522155 19th Jul 2019 9:04am
DrRob
Sorry, ignore me Whistle Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #522158 19th Jul 2019 9:37am
mm289
So had a go at this this arvo, still couldn't see a leak anywhere even with the wife revving the engine with me under the hood so bit the bullet and took of the inlet mainfold.
And hey presto, think this might be the culprit Razz
Offside rear boot split underneath. The opposite one wasn't split but there was a fair bit of soot on the pipes underneath so might have been leaking as well. As Baltic Blue said, once you are near the split its pretty obvious as its covered in soot/oil residue Shocked
So I ended up ordering a 1m length of 70mm ID silicon mainly as I had to do it quickly whilst at work yesterday and didn't have time to check lengths etc, otherwise those couplers would probably have been ideal.
But a 1m length was only £34 with next day delivery so pretty good really compared to £25 a pop for the Britpart ones and goodness knows how much for LR Surprised
So, quickly cut 4 lengths (tip: if you use one of the jubilee clips it makes a great guide on where to cut the silicone so you get the cut kinda square Thumbs Up )
Then fitted and replaced inlet mainfold
Just been for a quick blast and everything is back to normal (or better actually, reckon I was loosing some boost for a while with that split).
Now just have to track down the oil leak - the smell drives me mad but its not enought to be obvious - done all the normal o-rings and oil filter housing seals, oh and just got a transmission filter and fluid kit so that needs doing as well Rolling Eyes
Still, at least its running "proper" now Laughing
Cheers,
Paul. 2011 TDV8 AB
Post #522217 19th Jul 2019 6:49pm
DrRob
Excellent news Thumbs Up
Keep us posted on your oil leak diagnosis..... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #522218 19th Jul 2019 7:34pm
Page 2 of 4 <1234>
