![]() | Home > Maintenance & Mods (L322) > Height sensor problem |
RRAustria Member Since: 07 Apr 2015 Location: Graz Posts: 32 ![]() ![]() ![]() |
Still dealing with the issue...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
when you were on the motorway the suspension lowers around 65mph..this action seems to have triggered your problem...check connections/plugs for broken wires or corrosion.. ... - .- -.
Will do. what puzzles me is that the error seems to be connected to the motorway speed and not the actual height (I get the error regardless of motorway setting - tried -20mm and 0mm drop as well as locked suspension). I was under the impression that the sensor only sends a height signal and speed is determined through the ABS sensors? |
yelnats69 Member Since: 21 Dec 2019 Location: Dymchurch Posts: 35 ![]() ![]() ![]() |
Did you solve the problems |
yes, I switched the sensors from one side to the other and recalibrated everything. Worked fine after that. |
