Home > Maintenance & Mods (L322) > Rust on RHR wheel arch
Doonhamer
Anybody had this problem? My 15 year old TD6 has rust coming through at the bottom of the wheel arch; only visible when you open the door. Iā€™m thinking standard treatment - rub down, Kurust, primer and paint - unless anyone has any other suggestions? Been a long time since I had a motor with rusty bodywork. L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Suzuki Grand Vitara XL7 - sold
Mitsubishi Pajero 2.8 - part ex'd
Hyundai Santa Fe 2.0 td - sold
Mitsubishi Pajero 2.8 - sold
Post #521959 16th Jul 2019 8:35pm
DrRob
Plastic sill needs removing to check for any additional rot Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #521960 16th Jul 2019 8:46pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Probably lots of rust under the plastic. I had holes in both sills.
Also check passenger side between rear bumper and fender/wheel arc. Mine was rusting through from the inside. 2007 L322 3.6 TDV8 Stornoway
Post #521962 16th Jul 2019 9:22pm
Doonhamer
Thanks for the tips, guys - do they come off easily? L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #521964 16th Jul 2019 9:35pm
bobsin
2004 Range Rover Vogue Td6 Epsom Green
be prepared!! this was my '04 with plastics removed after i knocked out all the rot, now welded up behind covers
Post #521968 16th Jul 2019 10:33pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Shocked
I will be waxoyling when I get home........
Jim
Post #521977 17th Jul 2019 4:27am
S.Hafsmo
Seems like this is rusting from outside - in? Is it caused by dirt stuck between plastic and metal?
And obviously nobody makes replacement sills. 2007 L322 3.6 TDV8 Stornoway
Post #521978 17th Jul 2019 5:51am
Doonhamer
Shocked Shocked Shocked Home mine's aren't that bad! I'll be checking soonest! L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #522008 17th Jul 2019 12:58pm
Anvil
Oops, Sorry!
I've not been on the forum for a while, and just posted a very similar post in the tech section. Seems I was a lot luckier than a lot of people. It has to be sorted early was my message and we have to stay on top. It's a sin that such a highly thought of (and bloody expensive) vehicle has such a vulnerability. Good luck with getting it sorted.
Post #522012 17th Jul 2019 1:16pm
kbald
They come off easily yes. Pull out the centre pins under the bottom of the plastic sills. Remove the nuts from the mud flaps if fitted the open the rear door and prise the plastic from the metal sill and then do the same with the front door open. Current 2007 TDV8 Vogue Buckingham Blue
Post #522037 17th Jul 2019 6:15pm
Doonhamer
Thanks again for the input, especially kbald- I'll keep you posted! šŸ˜‰ L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #522067 17th Jul 2019 10:19pm
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I have the same problem both rear jacking points collapsed. Anyone had the skills replaced and got an idea of cost?
Post #522094 18th Jul 2019 12:36pm
Having seen some of the above examples of corroded sills, bit the bullet today and took the sill covers off my 2004 TD6.
Got a bit of a shock, the sills are almost as new, the only corrosion was a minute bit on the surface around the rear clip positions and a small amount of surface corrosion on the rear flanges of the sills, both sides exactly the same.
The sills are absolutely solid.
The small amount of corrosion around the rear clip positions was almost certainly due to a build up of soil in the small pocket on the rear of the sill covers given the amount of soil I removed from each.
Gave the sills a wipe down, applied a liberal coat of grease to them and refitted the covers for another 15 years.
I really was expecting the worst and can't understand why some cars suffer really badly from corrosion behind these covers and some seem to be ok.
Another reason not to sell the car for a while, I do like to get my monies worth. Thumbs Up
Post #522118 18th Jul 2019 4:32pm
S.Hafsmo
How did it look? 2007 L322 3.6 TDV8 Stornoway
Post #522654 24th Jul 2019 2:54pm
Doonhamer
Feeling very guilty, still not done it as other crocodiles were closer to the canoe, but will keep you posted! šŸ‘ L322 TDV8 4.4 - current
L322 TD6 - sold
Disco 2 TD5 - sold
Post #561305 13th Jul 2020 7:18pm
