Home > Maintenance & Mods (L322) > Caravan lights
killa
United Kingdom 2010 Range Rover Autobiography TDV8 Bonatti Grey
Caravan lights
Have no lights on van.
Indicators work but not hazard warning lights.
Reverse lights flash on car with hazards on.
No brake lights.
Plugged van into friends car all ok.
So must be fault on car.
Where do I start looking..
2010 autobiography/ twin electrics.
Post #521933 16th Jul 2019 4:44pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Is your caravan 7 pin or 13 pin?
Post #521935 16th Jul 2019 4:53pm
killa
Does it matter that my car has led rear lights and the caravan has bulbs ?
Post #521936 16th Jul 2019 4:54pm
killa
Twin 7 pin plugs and sockets
Post #521937 16th Jul 2019 4:55pm
Tinman
It should not matter I have bulbs in my caravan changed from twin to single on the car to match the caravan Have you tried plugging your mate's caravan into your car?
Post #521938 16th Jul 2019 4:59pm
killa
Friends car only has single electrics for trailer use
Post #521939 16th Jul 2019 5:05pm
Tinman
Well if you have twin electrics 1 will be 7 pins the same as your mate's trailer and should work the same as your caravan the other plug is for running a fridge, charging caravan batterie.
Post #521941 16th Jul 2019 5:25pm
killa
Yes the only thing that's not on with friends car was reverse lights which I believe are in other plug.
Post #521944 16th Jul 2019 5:33pm
Tinman
Can you check the plug in the spare wheel area for corrosion?
Post #521945 16th Jul 2019 5:45pm
killa
Just checked fuses.
And plug in wheel well.
All seem ok.
Taking car to auto electrician tomorrow will update with his findings
Post #521953 16th Jul 2019 7:09pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
You have an earth problem and it's back feeding via other lights etc. Check inside the socket on the car, check the pins for corrosion etc. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #521954 16th Jul 2019 7:11pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Some cars do not recognise led trailer lights and require a modification to get them to work correctly. These issues are well known and a quick google of specific car/ year and caravan will give you the relevant fix. Generally it is the combination that causes the issue a different car will work the lights. Otherwise trailer light issues are generally earth problem related. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #521973 17th Jul 2019 12:40am
killa
Been to autoelectrician today car wiring was all ok.
Replaced plugs on caravan . Now got lights working.
Could do with cleaning sockets on car.
Would wd40 do this ?
Post #522058 17th Jul 2019 8:13pm
Brian Considine
GT85 is better (IMHO) than WD40.
If the sockets are really bad then I would replace them & sparay them occasionally with GT85. 2003 Range Rover Vogue TD6
Post #522062 17th Jul 2019 9:24pm
AJGalaxy2012
You said "Plugged van into friends car all ok" so how could it have been the caravan plugs or have I understood it wrong? BMW i3 Electric Car
Post #522066 17th Jul 2019 10:03pm
