![]() | Home > Maintenance & Mods (L322) > Caravan lights |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
Is your caravan 7 pin or 13 pin? |
killa Member Since: 23 May 2019 Location: birmingham Posts: 20 ![]() ![]() ![]() |
Does it matter that my car has led rear lights and the caravan has bulbs ? |
Twin 7 pin plugs and sockets |
It should not matter I have bulbs in my caravan changed from twin to single on the car to match the caravan Have you tried plugging your mate's caravan into your car? |
Friends car only has single electrics for trailer use |
Well if you have twin electrics 1 will be 7 pins the same as your mate's trailer and should work the same as your caravan the other plug is for running a fridge, charging caravan batterie. |
Yes the only thing that's not on with friends car was reverse lights which I believe are in other plug. |
Can you check the plug in the spare wheel area for corrosion? |
Just checked fuses.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
You have an earth problem and it's back feeding via other lights etc. Check inside the socket on the car, check the pins for corrosion etc. BMW i3 Electric Car
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 373 ![]() ![]() ![]() |
Some cars do not recognise led trailer lights and require a modification to get them to work correctly. These issues are well known and a quick google of specific car/ year and caravan will give you the relevant fix. Generally it is the combination that causes the issue a different car will work the lights. Otherwise trailer light issues are generally earth problem related. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Been to autoelectrician today car wiring was all ok.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
GT85 is better (IMHO) than WD40.
You said "Plugged van into friends car all ok" so how could it have been the caravan plugs or have I understood it wrong? BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
