Home > Technical (L322) > Restricted Performance fault TDV8 4.4 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
The secondary turbo change-over valve may be sticky - the original design's external linkage was problematic.
15th Jul 2019 8:45pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Thanks Graeme, just trying to google pics of it so I know what I am looking for .....
15th Jul 2019 9:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
I think the EGR readings are a bit of a red herring sir as the 4.4 only gets one EGR because of the sequential turbo's... |
16th Jul 2019 12:14am |
https://www.fullfatrr.com/forum/topic49556.html?highlight=csov |
16th Jul 2019 3:10am |
Thanks for the info CTC
16th Jul 2019 6:38am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
LTB 00504 v3 dated 18th February, 2013.
16th Jul 2019 8:15am |
Thanks Mike - I have googled that reference from one of your other posts but nothing comes up - don't suppose you have a copy of the TSB?
16th Jul 2019 10:33am |
Paul,
16th Jul 2019 10:55am |
That's perfect thanks
16th Jul 2019 10:58am |
16th Jul 2019 12:56pm |
I've checked and mine does have the nut, am dribbling oil on it during the course of today so will see if it makes a difference. Hoping this is the problem but need to try and isolate to be sure, I am guessing the difference in readings on the bank2 boost live values is the give away but we will see
16th Jul 2019 1:05pm |
I think I would be tempted to take the nut off, then give a good squirt of WD 40.
16th Jul 2019 1:27pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
mm289,
16th Jul 2019 2:15pm |
Cheers, Nino 2011 TDV8 AB
16th Jul 2019 3:43pm |
