Home > Technical (L322) > Restricted Performance fault TDV8 4.4
Page 1 of 4 1234>
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Hi all,
last week or so I have had a couple of restricted performance faults. First time it happened was on motorway at 70, pulled over in services and no obvious fault code so cleared faults and it was fine.
Had a chance to have a look at some of the posts on this and usual suspects seem to be things like the intake rubbers so went for a play today.
Can't replicate fault on sedate driving but did get it to go into restricted mode on the motorway if I accelerated heavily. The only engine fault being thrown though was a U0405-68 invalid data recieved from speed control.
Cleared faults and it was OK again.
I have had live values on and seem to be getting strange or no readings for bank 2. EGR2 shows no data, boost actuator shows zero, if I boot it commanded boost actuator2 goes to 100% but actual boost actuator2 doesnt move etc......
Have been under the hood and checked the intake rubber boots whilst the engine is being revved and can hear/feel no boost leaks.
Any thoughts?
Cheers,
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #521810 15th Jul 2019 7:20pm
GraemeS
The secondary turbo change-over valve may be sticky - the original design's external linkage was problematic.
The valve can be spotted by looking directly down behind the radiator about half way between the centre and the left side.
Post #521817 15th Jul 2019 8:45pm
mm289
Thanks Graeme, just trying to google pics of it so I know what I am looking for ..... Rolling Eyes
Cheers,
Paul 2011 TDV8 AB
Post #521822 15th Jul 2019 9:06pm
I think the EGR readings are a bit of a red herring sir as the 4.4 only gets one EGR because of the sequential turbo's... Thumbs Up
Post #521847 16th Jul 2019 12:14am
GraemeS
https://www.fullfatrr.com/forum/topic49556.html?highlight=csov
Post #521851 16th Jul 2019 3:10am
mm289
Thanks for the info CTC Thumbs Up
Thnaks Graeme, thats awesome. I spent an hour on google last night and couldn't find anything, including on this site Rolling Eyes loads of 3.6 posts but no 4.4's so thats brill Thumbs Up
Cheers,
Paul. 2011 TDV8 AB
Post #521860 16th Jul 2019 6:38am
Baltic Blue
LTB 00504 v3 dated 18th February, 2013.
details the problem and fix.
Post #521867 16th Jul 2019 8:15am
mm289
Thanks Mike - I have googled that reference from one of your other posts but nothing comes up - don't suppose you have a copy of the TSB?
Cheers,
Paul. 2011 TDV8 AB
Post #521890 16th Jul 2019 10:33am
Baltic Blue
Paul,
I have got a paper copy of it, but unfortunately no scanner.
I will add photos of each page and hope you can read it.
Post #521896 16th Jul 2019 10:55am
mm289
That's perfect thanks Thumbs Up
Paul. 2011 TDV8 AB
Post #521898 16th Jul 2019 10:58am
Baltic Blue
If it helps, mine is a March 2011, build date and it was fitted with the old design with the nut.
They tried to free it up, but it kept sticking, so they replaced it with the new design.
Post #521911 16th Jul 2019 12:56pm
mm289
I've checked and mine does have the nut, am dribbling oil on it during the course of today so will see if it makes a difference. Hoping this is the problem but need to try and isolate to be sure, I am guessing the difference in readings on the bank2 boost live values is the give away but we will see Rolling Eyes
Cheers,
Paul. 2011 TDV8 AB
Post #521915 16th Jul 2019 1:05pm
Baltic Blue
I think I would be tempted to take the nut off, then give a good squirt of WD 40.
It only moves a fraction of a mm.
Post #521918 16th Jul 2019 1:27pm
nino_nino
mm289,
if you take hose that goes from intercooler to throttle body then valve can be reach from above. aplay external vacuum and see if it moves, you can help with your finger to if it is stuck. Thumbs Up
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #521923 16th Jul 2019 2:15pm
mm289
Cheers, Nino Thumbs Up 2011 TDV8 AB
Post #521932 16th Jul 2019 3:43pm
Page 1 of 4 1234>
