Home > Maintenance & Mods (L322) > How to tell which rear diff you have? ELectronic or not? |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
From what I've gleaned, the ediff oil contains the same additive used in LSDs and that some brand diff oils of the correct viscosity contain the additive which previously had only been used in HD LSD oils. Using non-LSD oil in a LSD causes shuddering. |
27th Jun 2018 10:14am |
Walkeraj101 Member Since: 25 May 2019 Location: Wirral Posts: 3 |
Hi Rapiscan, I've just completed my oil change on my rear diff and the posts here were very useful. Mine is a 2007 TDV8 and has the Ediff. The picture from GremeS is great but the only thing I can add is that you get a better idea of it being Ediff from the other side. You will see a black canister similar to a small spray can in size on the top of the diff. You can just make it out on GraemeS pic. You definitely have an Ediff if you see this.
15th Jul 2019 6:26pm |
